Fokker D VII 1/6 RC
    Fokker D VII 1/6 RC
    I had a Flair Fokker d7 rc model many years back powered by an OS .70 FS.
    It was one of the nicest flying scale planes I had so since I had the plans and former/rib blanks from the original kit I will be building another one.
    I cut out all the fuselage formerg from ply I had lying in the shop and the balsa for the ribs was also extra I had from other builds.
    The spars I had to join to get the 1/4m for the one piece top wing.
    I think I might go for Ernst Udet's "LO" red and wight ride.
    Covering wil be light weight poliester and dope.
    Theuns
  • colin m
    • 8755
    • Colin
    • Stafford, UK
    I like the sound of this. A proper flying machine.
      I wans't sure if this is the right forum for it , I have seen some RC builds before but could not find those threads.
      The top wing has been started, I will have to think about the mounding system that the kit used for the cacane and interplane struts. They were piano wire with soldered on lugs for the fastners.
      I didnt like this much. I might go for thin metal tube that is flatened and bolted together, it might look closer to the rear thing.
      It will be a stand off scale , I am not going mad with the scale detail, the real DVII had an interesting wing that became thinner from root to tip, the kit has a constant thickness.
      Theuns
        • 22770
        Well I going to watch this one Theuns. Great start
          The top wing basic structure is taking shape, it has been framed up and the LE sheeting glued to the leading edge. When this is dry I form it around the nose ribs. It forms  D-box structure that is very resistant ot tortional loads.
          I will also add shearwebs between the top and  bottom spar caps, it forms a C-beam that is way stronger than just the caps on their own.
          Theuns
            Work got in the way of play time so progress was a little slow.
            I have basically completed the top wing and ailerons, I just need to put on the wingtips and strut mounds.
            The stab is on the board now.
            I have used a different method on the controll surfaces than the kit. I laminate thin strips of balsa, its way stronger and lighter.
            Theuns
            • flyjoe180
              • Jan 2012
              • 12407
              • Joe
              • Earth
              I love seeing these wooden structures go together. I'm looking forward to the next instalments Theuns.
                Fuselage side frames done, all tail pieces done and topwing plus ailerons done.
                I just need to build in the mondpoints and build the bottom wing before I can start rigging it.
                Theuns
