Bristol Bulldog
  • Gwyn
    • Dec 2015
    • 399
    Bristol Bulldog
    I was wondering which model to do after finishing the Stephenson's Rocket when I found an old Profile magazine covering the Bristol Bulldog.
    I must have had this for a few years as it cost me 35pence.
    Then I searched in my stash and found this.
    Looking on the internet, this seems to have been produced about 1993.
    well I thought I had given up on 1/72 as a scale, to small and fiddly for my fingers nowerdays, but after finding the Profile and the kit I thought well have a go and see how you get on.
    has anyone else made this? any tips?All help gratefully received.
    A great choice - good luck with it. I've made one (using the Profile as reference), but it was in the 1980s, so I'm afraid I don't remember much about it. It's one of Airfix's better offerings for its period (early 70s I believe). One obvious challenge will be disguising the strut 'tie bar' in the top wing. I made a lot of 1/72 biplanes at the time, and always ended up putting the top wing on right at the end - complete with paint, decals, etc. - with just the rigging left to do afterwards. I will have glued the interplane struts to the top wing, then filled the bar in and sanded it down before painting.
    • colin m
      • 8741
      • Colin
      • Stafford, UK
      Nice one Gwyn, one true scale as some like to call it. It will be nice to see this old kit come together.
      • Gwyn
        • Dec 2015
        • 399
        Thanks Douglas I will keep that in mind when making it .
        • flyjoe180
          • Jan 2012
          • 12390
          • Joe
          • Earth
          Hi Gwyn, the Bulldog is a nice looking biplane. I've got one waiting in the wings too. It's a kit that's been made a few times and displayed on this forum, if you try a search you might find some helpful tips from the older posts.
          • Gwyn
            • Dec 2015
            • 399
            Good suggestion Joe I will do that.
            • Gwyn
              • Dec 2015
              • 399
              Well I have made some progress.
              a bit of paint on the inside of the body (sorry about the finger)
              A bit of PE instrument panel.
              [ATTACH]270856[/ATTACH]
              [ATTACH]270857[/ATTACH]
              Here is the progress on the rotary engine
              [ATTACH]270858[/ATTACH]
              And here is my pilot.
              I thought hard about trying a 1:72 plane because I thought my not very steady hands would not be able to manage. I have been pleased so far with the results even though after taking and looking at the macro photographs that I need to touch up a few things.
                • 22770
                Nice start Gwyn, the pilot looks good
                • colin m
                  • 8741
                  • Colin
                  • Stafford, UK
                  The engine and prop look nice. Are they standard kit items ?
                  • Gwyn
                    • Dec 2015
                    • 399
                    Thanks Ian, I appreciate your comments.
                    • Gwyn
                      • Dec 2015
                      • 399
                      Yes Colin standard parts that to me look a bit garish but hopefully will weather down. Thanks for your comments.
                        The detail painting looks great, Gwyn - especially when we remember the photos are about three times life size! The pilot is beautifully painted (and surprisingly well moulded considering its age).
                        • flyjoe180
                          • Jan 2012
                          • 12390
                          • Joe
                          • Earth
                          Nice work Gwyn, I'm watching your build progress.
                          • Gwyn
                            • Dec 2015
                            • 399
                            Thanks Joe.
                            • Gwyn
                              • Dec 2015
                              • 399
                              Well after putting the pilot in and joining the two sides of the fuselage, I masked over the pilot just with some kitchen towel.
                              [ATTACH]271286[/ATTACH]
                              As can be seen there are quite bad join marks that would need sanding out. Well to make it easy to handle i decided to mount a piece of small dowel to the nose area, that is when disaster struck. As I was in too much of a hurry I accidently picked up the runny super glue and instead of putting a nice drop ready to attach the dowel I squirted runny super glue all over the plane. I have spent ages sanding off the glue before setting to work on the joint lines.
                              [ATTACH]271293[/ATTACH]
                              [ATTACH]271294[/ATTACH]
                              So all smoothed and primed ready for the next step. Sorry about the shadow it's not my finger but the lens extended to macro mode. I will have get some independent lighting for closeup work.
