Revell 1/48 BF 110
    Revell 1/48 BF 110
    [COLOR=rgb(50,61,79)]Cockpit after pinting and some pinwashes then matt clearcoay to seal it all. I didnt have to add anything except the maskingtape seatbelts.[/COLOR][COLOR=rgb(50,61,79)]The IP was done the same but with acrylic clear on the instrument faces.[/COLOR][COLOR=rgb(50,61,79)]This is an interesdting kit in that in some areas the moldings are very crisp and in others there is loads of flash to be cleaned off. Also the reccesed detail on the bottom of the left wing is allot lighter than the right wing, a little scribing will be needed here.[/COLOR]Theuns
    I have found that using a white correction pen as a fillr for seams, the sanding becomes less of an issue. Look at the top of the necell to see.
    The fit of the parts was a little chalanging, but if you glue it is sections it works out OK.
    Theuns
      • 22770
      Great start Theuns
        Coming along nicely mate. The interior looks great, nice detail.
        • colin m
          • 8740
          • Colin
          • Stafford, UK
          Is there no stopping him. You would think he would like a rest after that 1:32 Mustang. All looks very nice by the way.
            Ta Colin.
            These builds are actually "therapy" ,mate. I have been waiting for a plane to come off the line so I can start working on it but have been held back for a few weeks now. If you are an indebendent contractor like me who only gets paid when you work it becomes "troublesome" quite fast and I need something to stop me going mad ;-)
            Theuns
              [COLOR=rgb(50,61,79)]I primed the 110 to see if my rescribing was OK...[/COLOR][COLOR=rgb(50,61,79)]It went on a little rough so I sanded it withy wet 2000 paper...[/COLOR][COLOR=rgb(50,61,79)]Needless to say I went through the primer in some places [/COLOR][COLOR=rgb(50,61,79)] But then the idea struck me - I am going to try a nw tecnique where I use the light spots and add some dark spots to simulate how the paint might fade....hope it works.[/COLOR]
              Theuns
                Hi Theuns.
                I won a Revell bf110G in a competition about 18 mnths ago. It came without decals and Revell kindly replaced them. Although a couple of the decals were damaged and unusable. However, luckily I have a couples of spares fro another kit that I can use.
                I am dealing with a lot of flash too. But, the worst thing is a really poor fit between top halves of both wings and the fuselage.  The worst example I've ever seen. Had to use a load of filler.
                Anyway, lovin your work on the cockpit interior. It's much better than my effort, although I'm happy enough with what I have done so far.
                What variant of the 110 are you building?
                  Hye Bruce.
                  I had no hassles with the fit on my top wingroot, maybe just lucky. I have found if I have to fill something like that is to use stretched sprue and thin cement. It has the same consistancy at the rest of the plastic and sands at the same rate.
                  As for the colour scheme, I am not sure yet....
                  Theuns
                    Looking very nice so far.
                    • yak face
                      • Jun 2009
                      • 13829
                      • Tony
                      Great start Theuns , its a nice kit isnt it ? , Ive got the same kit but in the G-4 Nightfighter Promodeller boxing .I'll be watching to get some tips for when I do mine . cheers tony
                        Tony the kit is not fantastic but with a little work it is a great canvas to try new things. Like with most monogram stuff of the 90's the detail is actually very nice, the fit is substandard but workable.
                        Theuns
                          • 22770
                          It's coming along nicely Theuns, and i would like to see how the primer effect looks when painted. A nice idea if it works.
                            Super job on the interior there Thuens. You do interiors very well, as you did with your Seaking too. Really looking forward to this one mate.
                              Here is the bottom RLM76 Light Blau with preshading.
                              Theuns
