Very, very nice indeed
1/32 Trumpeter Messerschmitt Bf 109G-2 Gunther Rall JG52
Have out the main airframe together with lots of sawing and sanding to get the plastic parts to fit. However, no major gaps have been encountered. I also sawed open the slat struts in preparation to pose them open
Cheers, John
[ATTACH]271987[/ATTACH]
[ATTACH]271988[/ATTACH]
[ATTACH]271989[/ATTACH]Comment
[ATTACH]272191[/ATTACH] Next update- primed and pre shaded All gaps have been filled and sanded. Just some minor imperfections remain to be fixed
Oh, and Happy New Year
[ATTACH]272190[/ATTACH]Comment
That's interesting, I've never seen a model at this stage before with the panel lines sprayed black onto the primer coat. I'm still honing my skills at the moment and wonder if you could tell me, does the pre-shading work if you use brushes or is that mainly an effect better done with a spray gun? the reason I ask is that i'm currently in the process of building a Hawker Hurricane Mk1 and might consider trying this techniqueComment
Cheers, John
[ATTACH]272227[/ATTACH]Comment
Very well done there John. Its hard to get all those preshading lines in order but youve done well mateComment
Cheers, John
JohnComment
Next update. RLM 04 Gelb and RLM 76 Lichtblau has been sprayed onto the under surfaces. Also, the wing roots have been sprayed with aluminum and the same has been done for the radio hatch, then I have used Mig Chipping fluid (hairspray technique) to create a worn effect. The pre shading has turned out really well, giving a nice perception of depth and tonal variation
Cheers, John
[ATTACH]272332[/ATTACH]
[ATTACH]272333[/ATTACH]Comment
