Roberts Tamiya 1/48 Swordfish ( with extras)
  • Robert1968
    • Mar 2015
    • 3596
    Well I have mulled over when I'm going to start this and now is the time. I will be building OOB so to speak but I have taken the opportunity to get some extras to make it that much more appealing ( my opinion )
    I'm a little confused as of yet which to do though
    Options are Fairey Swordfish Mk2 836Sqn MAC - Ship Amastra 1943-44
    Fairey Swordfish MK 2 816Sqn HMS Tracker 1943
    Fairey Swordfish MK 2 810Sqn Tanzania 1942
    Or something else as I'm open to suggestions
    Extras I have purchased are:- Tamiya Photo etch Bracing wires ( still not sure if I will use these as I'm led to believe they are a bit overscale.
    Eduard FE384 cockpit detail ( self adhesive )
    Ammo Rigging wire 0.2mm
    Ammo Rigging Wire 0.3mm
    HGW 148005 Sutton Harness
    Plastruct round rod 0.5mm 90851
    Plastsruct Round rod 0.3mm 90850
    The Plastruct is I'm hoping to replace the rigging in place of Tamiya Bracing but this will be anew venture for me.
    I've taken some notes from the Internet IE Brett green and others in their constructions of the Swordfish.
    I'm hoping to put in control wires in as well that will hopefully represent my aircraft better.
    I've looked at some nice weathering too from others and washed and stains will all be incorporated so wish me luck.
    Ok the box. Shots and some sprue shots etc
    [ATTACH]272402[/ATTACH] [ATTACH]272403[/ATTACH] [ATTACH]272404[/ATTACH][ATTACH]272405[/ATTACH] [ATTACH]272406[/ATTACH] [ATTACH]272407[/ATTACH] I
    Thanks for looking and any feedback would be most welcome ( advice etc
    Regards
    Robert
  • colin m
    • 8741
    • Colin
    • Stafford, UK
    Nice one Robert, I look forward to watching this being built. I mentioned somewhere else I have one to build as well. Like you, I'm really not sure about the Tamiya PE rigging either. I'm thinking I might try a large ish fishing wire painted in the relevant colour.
    • Robert1968
      • Mar 2015
      • 3596
      Thanks Colin
      I was looking down the same route as Fishing line too and there were a few available n I saw a Swordfish using Plastruct and think I can only try and if it doesn't work I've got a fall back
      Regards
      Robert
        • 18266
        It's a very nice kit and builds very well. The PE can be a bit tricky but looks the part. Note that the bracing wires where not round, more like a flattened oval. The PE matches that quite well.
        • Robert1968
          • Mar 2015
          • 3596
          Update.
          Well I have made some progress in between the HMS Rodney.
          The two fuselage halfs have been sprayed and the cockpit frame constructed and painted.
          PE detail is throughout the cockpit with harnesses and dials
          The pilots control facial was difficult to sand smooth but the PE detail looks amazing.Very 3D still have to affix gunners seat belts/ harnesses before a wash
          Paints used Tamiya and Vallejo
          Still lots to do before I seal up ( all parts given a Klear coat and will be given another before wash begins. Then it's chipping before I seal all up
          Comments welcome
          Pics of progress
          [ATTACH]273859[/ATTACH] [ATTACH]273860[/ATTACH] [ATTACH]273861[/ATTACH] [ATTACH]273862[/ATTACH] [ATTACH]273863[/ATTACH][ATTACH]273864[/ATTACH] [ATTACH]273865[/ATTACH] [ATTACH]273866[/ATTACH] [ATTACH]273867[/ATTACH]
            Nicely done Robert, looks an impressive kit.
              That looks very good Robert, although the IP is a tad blurry to my eyes!
              Watch out for those ejector pin marks though in future builds. It's a shame to put so much great work into the cockpit, only to have it marred by leaving those marks.
              Looking forward to seeing more of this one
              • Robert1968
                • Mar 2015
                • 3596
                Thanks Patrick
                When I've done a lot of dry fitting the fuselage doesn't seem to show the Ejector pin marks but I'll attend to those and re paint ( better safe than sorry eh )
                I'll try and get some clearer pics up next.
                Thanks
                Robert
                • Robert1968
                  • Mar 2015
                  • 3596
                  Thanks Graham.
                  • Robert1968
                    • Mar 2015
                    • 3596
                    Some more instrument panel pics
                    Enjoy
                    I still have to scratch a compass as PE says to cut off so that will be another challenge.
                    [ATTACH]273883[/ATTACH] [ATTACH]273884[/ATTACH]
                    • colin m
                      • 8741
                      • Colin
                      • Stafford, UK
                      Nice start. You've spent a bit of time on the 'pit and it shows. I'm looking forward to the rest of your build.
                      • Robert1968
                        • Mar 2015
                        • 3596
                        A little more progress today I have done some washes with oils and made a start on the engine. I will look at some more pics of the Pegasus at the weekend to see if I can improve with ignition leads etc. I have also made a few more sub assemblies painted the inner cowl and gave a dry brush.
                        I'm still not sure on a version I'm going to do but I'm leaning to the white version from MAC ship AMASTRA of 836Sqn. I think this version will get me more practice in the art of oil streaks and dirt streaking. Oh I noted on one of the sub assemblies there are two small bumps which I nearly cut off when cleaning up ( I have marked with pen on pic as these must stay in place ( part of the upper wing support
                        Pics of progress
                        Enjoy and comments welcome
                        [ATTACH]273994[/ATTACH] [ATTACH]273996[/ATTACH] [ATTACH]273998[/ATTACH] [ATTACH]274001[/ATTACH] [ATTACH]274003[/ATTACH] [ATTACH]274007[/ATTACH] [ATTACH]274008[/ATTACH] [ATTACH]274009[/ATTACH][ATTACH]274010[/ATTACH] [ATTACH]274014[/ATTACH] [ATTACH]274015[/ATTACH] [ATTACH]274005[/ATTACH]
                        • PhilJ
                          • May 2015
                          • 1145
                          This is all looking very nice Robert, should be a really decent example when finished. Will be watching this.
                          Phil
                            Really cool detail, the IP looks good :-)
                            I have been after this kit for a long time but budget does not allow it , is I got the 1/72 new Airfix one instead .
                            Theuns
                              • 18266
                              A lot of work going into this and it shows. Its a great kit and builds well but the extra detail that you are putting into it is time well spent.
                              Re your oil washes. Next time you are at the shop, get some Payens grey. I find it very nice for grime and such. As for the colour, it is just the 'perfect' non de-script grey that just works with just about any colour under it.
