Rick's Airfix 1/72 Harrier GR3 - engine change & crew in
    I am following this one looking fantastic so far, keep up the good work.
    • rickoshea52
      • Dec 2011
      • 4076
      • Rick
      #32
      The Unimog has been transformed from an orange abomination into a NATO potato green & black camouflage scheme. With the decals on a sealing coat of varnish will be applied before some light weathering then reassembly. The decals are spares from JB Models Landrover kits.
      [ATTACH]281527[/ATTACH]
        • 22770
        #33
        Nice work Rick
          Liking this one Rick, looking good so far matey.
          Have fun, John
          • rickoshea52
            • Dec 2011
            • 4076
            • Rick
            #35
            All back together for the Unimog, next will be some light weathering and some bits to go in the load bed, maybe some wing mirrors.
            [ATTACH]282823[/ATTACH]
            • flyjoe180
              • Jan 2012
              • 12407
              • Joe
              • Earth
              #36
              I like that Unimog Rick. Harrier is coming along nicely, a good thing you didn't cut the wrong places earlier per the instructions
              • yak face
                • Jun 2009
                • 13841
                • Tony
                #37
                Excellent work rick , keep the updates coming its great to watch! Cheers tony
                • rickoshea52
                  • Dec 2011
                  • 4076
                  • Rick
                  #38
                  I found a pair of resin trailer loads from Kingfisher miniatures that I forgot I had, by good fortune they fit the load bed on the Unimog perfectly. This isn't really what you would find as a load, the limited photos I have seen of Unimogs in the field show them with a water tank - I assume for the Harrier's water aspiration system - but I cannot find a clear photo to scratch build an accurate replica.
                  [ATTACH]284109[/ATTACH] [ATTACH]284110[/ATTACH]
                    • 22770
                    #39
                    Well I think the load works a treat Rick.
                    • Steve Brodie
                      • Sep 2014
                      • 4652
                      #40
                      looks fine
                      • col68
                        • 1505
                        #41
                        Looks good to me rick. They were also used as A/C tugs in the field
                        • rickoshea52
                          • Dec 2011
                          • 4076
                          • Rick
                          #42
                          Yes, I've seen footage of them towing aircraft, i have a Flightpath airfield accessories kit that has a tow arm so I have that option to add some interest.
                          • rickoshea52
                            • Dec 2011
                            • 4076
                            • Rick
                            #43
                            A bit of progress on these over the last week or so. So they are assembled for painting with the cockpit surround and canopies sprayed black then a primer coat, after that the grey followed by the green. Applying the white tack worms was a real drag, twice over! This wrap around camouflage scheme is just horrible to do, I got a bit cross eyed at times. I used foam ear plugs cut length ways for the intake masking blanks, I will try using this to replicate intake blanks on the finished model.
                            [ATTACH]284750[/ATTACH]
                            [ATTACH]284752[/ATTACH]
                            [ATTACH]284753[/ATTACH]
                            [ATTACH]284749[/ATTACH]
                              • 22770
                              #44
                              Its all coming along very nicely Rick
                              • rickoshea52
                                • Dec 2011
                                • 4076
                                • Rick
                                #45
                                Now unwrapped. There was a fair bit of touch up required where the maskol didn't cover the grey - this is the first time trying the camouflage this way as I didn't fancy cutting up loads of tiny bits of masking tape for the infills.
                                You can see some of the add on bits, I applied a lighter shade of green to the top side of the drop tanks and also on the aircraft.
                                [ATTACH]284820[/ATTACH] [ATTACH]284821[/ATTACH] [ATTACH]284822[/ATTACH]
