Been there done that with the tac rolls. Great work on the wrap around scheme Rick, looking very good.
Rick's Airfix 1/72 Harrier GR3 - engine change & crew in
With varnish applied its time for decals, these Harriers don't have as many as Airfix's Lightning (as some of you are about to find out) but I do have to do it twice . You may notice that the under wing serials straddle the wing pylons, its best to add the pylons after the decals.
[ATTACH]286388[/ATTACH] [ATTACH]286389[/ATTACH]Attached FilesOn the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Comment
Thanks Colin. If you could compare the models side by side you might revise that accuracy comment, one of the things that bother me with these models is the fuzziness of the colour borders. Most references I see have a hard green/DSG border.On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
More decals. One other point on these decals, the tail RCS exhaust warning decals are tricky to apply as they go over a tight radius and ordinary setting solution won't help in sticking them down - I used Matt varnish to apply them.
[ATTACH]289138[/ATTACH] [ATTACH]289139[/ATTACH] [ATTACH]289140[/ATTACH] [ATTACH]289141[/ATTACH]On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
Thats a couple of very nicely turned out models you have on the go there.
Your paint scheme looks really very neat.Comment
After thinking this through with a clearer head and sizing up both Harriers to assess the size of base required I just don't have the space available for a two ship diorama plus all the vehicles etc. So using this box frame and some polystyrene sheet I want to try and create a field hide site with slightly uneven ground. I have seen some hide sites with the Harriers taxiing from the PSP rising onto a road, this is something I want to recreate. The use of a box frame gives me the option of including a culvert/ditch and foxholes - if the RAF ever bothered with them!
More later.
[ATTACH]290640[/ATTACH] [ATTACH]290641[/ATTACH]Attached FilesOn the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
