Alice Paper Fold Hindenburg
  • Bigfoot57
    • Jun 2015
    • 1101
    Hello everybody with my Aston Martin build stalled whilst waiting for longer bolts to arrive I have embarked on a totally diffrent type of model I've put this into the aircraft under construction thread as I can't come up with anything better to use for this build
    Anyway here's where I am with this one which has been ongoing for several months now the last picture also shows the Launch Umbilical Tower which is also under construction and is the next project to be finished this year hopefully
  • Bigfoot57
    • Jun 2015
    • 1101
    Latest update decided to remove coloured windows and replace with see through two pictures before and after
    Regards
    Colin
    • Bigfoot57
      • Jun 2015
      • 1101
      Latest update all coloured card windows now removed and replaced by clear frames just the gondola glazing to tackle now
      Regards
      Colin
      • monica
        • Oct 2013
        • 15169
        how great is that,will be quite a size,loooking good so far,
        • Bigfoot57
          • Jun 2015
          • 1101
          Thanks Monica I'm toying with idea of lighting it as now almost all the glassware is now clear and I did pre-drill all the celing lights through so a couple of led type stick on's should provide enough light for it look quite efective along with other lights inside to illuminate the other side and cabin windows
          Add a couple of navigation beacons and the huge I think it was 5 million candle power spotlight underneath the hull for illuminating the scenary at night and hopefully it won't exactly duplicate the real Hindenburg by bursting into flames
          Regards
          Colin
          • monica
            • Oct 2013
            • 15169
            do like the sound of your idea,and think it would,look great,
            • Robert1968
              • Mar 2015
              • 3596
              The Hindenburg always has fascinated me ( not just because of her ending ) suspicious as it was but her gracefulness and spender.
              I've seen a few models of airships and it amazes me in the grandaur of the builds
              This is taking such a step towards the same.
              This is really looking good Colin.
              Very impressive
              Kind regards
              Robert
              • Bigfoot57
                • Jun 2015
                • 1101
                Latest update roughly made up the gondola sides so I can see where to replace the printed windows with plasastrut and then fill in the resulting windows with microsol clear to form new windows thats the plan and after nearly 2 hours of cursing and swearing we have arrived at this point now waiting for the glue to set before gluing on top ring supporting frame
                Can somebody explain this one side of the structure glued fine no problems yet the other side was completely the opposite it seemed no matter how much glue you put on it nothing was going to stick without a fight yet it's the same material
                Regards
                Colin
                • Bigfoot57
                  • Jun 2015
                  • 1101
                  Update 19:56 03/03/2017
                  Now started gluing the top window frame into place as you can see the side that refuses to stick one of the uprights has fell off yet again oh well onwards
                  Regards
                  Colin
                    What an intriguing model. Looks really cool.
                    • Bigfoot57
                      • Jun 2015
                      • 1101
                      Update 22:11 04/03/2017
                      Gondola now complete very rough at the moment still full of glue and filler all needs cleaning off when completely dry and hardened will hopefully look far better when sanded and painted
                      • Bigfoot57
                        • Jun 2015
                        • 1101
                        After 5 attempts at producing a accurate looking gondola I'm now on version 5 which hopefully won't fall to pieces when cut and folded into a flowing curve 1st 4 pictures show the 4 dead ends the last 3 shows my current status basically I have glued down on top of the part all the ribs and then encased it in plastic glue in effect attemping to weld the parts together so that when all the background paper is cut away you should be left with a skeleton frame work the last picture shows the 1st section cut out it will need sanding smooth and cleaning up but it's looking hopefull will post more pictures of final outcome
                        Regards
                        Colin
                        • Snowman
                          • Oct 2014
                          • 2098
                          VERY BRAVE!!
                          That would honestly have me running for the hills!ops:
                          Impressive stuff!!
                          • Bigfoot57
                            • Jun 2015
                            • 1101
                            Hello everybody have now completed the rough cut of all gondolas windows now need to wait for glue to cure before filing windows square and remove the last remants of paper
                            The idea worked beautifully maybe some you can utilise it on some of your own builds you just need patience and a very sharp blade and steady hand
                            Regards
                            Colin
                            • Bigfoot57
                              • Jun 2015
                              • 1101
                              Ok final test the curve test will it hold together yes it did as can be seen from attached photo's so next job will to be to sand it smooth and then attach it to the bottom floor of the gondola
                              Regards
                              Colin
