airfix 1/24 hawker typhoon cardoor mk.1b
  • BarryW
    • Jul 2011
    • 6010
    #16
    I have just seen this one, glad that you are enjoying the build. Its a good kit Steve, well engineered, but does have a few issues. The soft poor quality Airfix plastic shrinks a bit too much in this scale and can cause fit issues on the larger parts, particularly on the panels, I recommend doing a lot of dry fits. They need a lot of clean up too, as I expect you have found - Tamiya this is not.... That said with my original 1b I found it a very nice satisfying build and mine looks great on the fridge in my office....
    A suggestion.... on aircraft of this scale paint masks really look much better than decals. Masketar do a set of roundels etc for the Tiffy, a really worthwhile investment.
      thank's barry , I know what you mean , for the life of me I can't get the main fuel tank's to sit properly under the wing's ,as you don't see them , I'm thinking of leaving them off
      [ATTACH]278781[/ATTACH]
        by paint mask's ,you mean make my own rounds ?, I have got some Tamiya sticker masking sheet's , never done it , could be interesting to have go .
        • BarryW
          • Jul 2011
          • 6010
          #19
          Hi Steve
          Great if you can make your own!!! Its not for me though...
          I used a set from Maketar on this link http://shop.maketar.com/?product_cat=124-aircraft
          • colin m
            • 8741
            • Colin
            • Stafford, UK
            #20
            You've certainly picked on a beast here, but it's all looking really good.
            • peterairfix
              • Jul 2012
              • 11074
              #21
              Just caught up again coming along nicely but just one thing I have got my undercarriage on and It is rather on the weak side so you might want to invest in some after market metal ones
                thank's peter , have heard that , and I will look into it , airfix plastic is pretty soft , I did a dry fit of the fuselage to the wings , as I have heard of some very bad fit issue's on other builds , I did have to cut out an alignment lug , but everything else seem's to be going together alright , did you glue your two halves together first peter or did you follow the the instructions , half at a time .
                  managed to get a bit of paint on , the colours have come out a bit darker in the photos , I did use Tamiya instead of humbrol , anyway here is the results
                  • Dave W
                    • Jan 2011
                    • 4713
                    #24
                    Its looking good Steve. Ive just started mine.
                    • Snowman
                      • Oct 2014
                      • 2098
                      #25
                      Looking the business!!
                        don't know if this help's , dave but this is a good tutorial on the build , 10 episodes .
                        wish I had listened a little bit closer too
                        • Dave W
                          • Jan 2011
                          • 4713
                          #27
                          Thanks. I will have a look at that.Ive got the book on how to build it as well
                          • Dave W
                            • Jan 2011
                            • 4713
                            #28
                            I just watched the first 2 episodes. All I will say is I won't be watching anymore!.
                            • tanktrack
                              • Jun 2012
                              • 1429
                              #29
                              that is a big plane ,1 of my favourites
                              • Dave W
                                • Jan 2011
                                • 4713
                                #30
                                Interesting film about the Typhoon.
