Rc Mirage 3 EZ
    Rc Mirage 3 EZ
    I have been working on this rc Mirage 3 EZ for some time. I was given an old brittle glass fuselage that I msade a plug from to make molds of. It took loads of elbowgrease to get it good enough to make a mold from.
    It will have foam core and balsa/composite wings, the fuselage will be aerospace epoxy glass and carbon.
    The prototipe wil be powered by an old .91 size IDF engine, they were never really as good as the new electric DF or turbine engines, so of it works on the old engine the newer ones will be even better.
    Theuns
  • PaulTRose
    • Jun 2013
    • 6549
    • Tattooine
    got me interested!
    Per Ardua
      I might do it in this scheme
      Theuns
        2 sets of wings cut. On the demo model set I put 2 deg of washout into the wingtips to compare with the wings that have 0 degs.
        I also had to figure out the position of the "hollow" cut out for the thrust and inlet ducts that fouls the centre section of the wing.
        You can also see the interesting airfoil shape of the root section now. I still need to decide what I am going to do WRT the hindging of the 2 elevons. I was thinking of making a top ""live hindge" with peelply but that will lead to a large wedge shape slot under the rear part of the wing....not sure what aerodynamic effect the high pressure airflow at high speed might have on it...
        T
        I rather cancy these colours of the RAAF, nice and visable
        Theuns[ATTACH]279832[/ATTACH] [ATTACH]279833[/ATTACH]
        OnlineOnline
          • 22788
          Great work Theuns so far, I like the RAAF colours too.
            I do like te SAAF camo, but mey eyes at the model's speed might now be compatable so I have to go high viz. the first one will be in SAAF scheme for someone else.
            Theuns
              I got the first one out the molds,m I am happy wit it. I had to design a ring former that gives the fin some stability aswell as glue in the rudder's hardpoints.
              Theuns[ATTACH]279965[/ATTACH] [ATTACH]279966[/ATTACH]
                The weather turned out to be nice and hot so I joined the fuse halves . While that is curing we are off the the model flying field, I am teaching my 2 daughters to fly RC....someone has to demo these models once the old man's eyes or skills have gone LOL
                Theuns
                  [ATTACH]280271[/ATTACH] The fusealge came out at 1030 gr, happy with that.
                  The wing is stupendisly strong and weighs 1200 gr.
                  The top hinging causes a large gap at the bottom so I molded some fairings to be glued to the elevon, this closes the gap a little better.
                  I also managed to get the very destinctive wingtips to shape, After a final sanding I will glass the wing.
                  Theuns[ATTACH]280265[/ATTACH] [ATTACH]280266[/ATTACH] [ATTACH]280267[/ATTACH] [ATTACH]280268[/ATTACH] [ATTACH]280268[/ATTACH] [ATTACH]280269[/ATTACH] [ATTACH]280270[/ATTACH]
                    Here are the molds for the intake and engine duckts
                    Theuns[ATTACH]280320[/ATTACH]
                    • PaulTRose
                      • Jun 2013
                      • 6549
                      • Tattooine
                      this all looks very impressive
                      Per Ardua
                        This looks so good!
                          Ta.
                          In the meantime I have completed the wing, ready to be glassed.
                          The intakes have been made up and ready to be installed.
                          Theuns[ATTACH]280465[/ATTACH] [ATTACH]280466[/ATTACH]
                          • yak face
                            • Jun 2009
                            • 13870
                            • Tony
                            Great work theuns ! Its going to look amazing when it flies, cheers tony
                              Thanx Tony I am sure it will.
                              I have managed to glass the bottom of the wing, will do the same ontop today than the priming and painting can start.
                              Theuns
