For those who do not know much about this kit Tamiya have been very innovative enabling you to produce a model with what I consider to be toy like features. This applies not just to the P51 but also the Spitfire and Zero in this series of 1/32s and to a lesser extent the Corsair and Mossie as well. Not just posable control surfaces but movable control surfaces, a sliding canopy, removable engine panels held by magnets and a swappable undercarriage held with a mix of screws and magnets enabling you to interchange sub-assemblies between wheels up and wheels down.
As you may guess I not a fan of this system as I build static models not toys. The engine panels, for instance, are great in theory but I have not found, in practise, that they work as well as theory IF your preference is for a 'buttoned up' appearance. While if swapping undercarriage you run the risk of weakening the components and having breakage. The Spitty on my view is more problematical that the P51 in this respect.
This is my third Tammy 1/32 Mustang having built two of the Spitties and two Zeros as well. All my models have been built wheels down and engine buttoned up. It is how I like to display them.
This results, with the P51, in a very easy way of masking the wheel wells. I use the u/c doors for the wheels up configuration as a mask. Plus one of the spare canopies for masking the cockpit (I prefer to paint the canopy used off the model). This means that the wheels legs get screwed on as a final fitting along with the central wheel well assembly.
If you decide to build this kit, as I do, buttoned up on a wheels down configuration make sure you do not Cement the front of the wheel well to the forward underside engine panel. The front of the wheel well needs to flex as if it doesn't not you will have a lot of sanding, scraping and filing to do to fit the centre part. You can seen in the photo what I mean.
[ATTACH]285900[/ATTACH]
Down the middle a bulkhead fits with the centre wheel well doors attached. It pushes in, fitting into the slot you see in the middle. There is visible a guide to the front that fits inside a groove. There is one out of view in the rear as well.
I use the Microscale Liquid Tape to temporarily fix the parts I am using as masks into place.
[ATTACH]285901[/ATTACH]
Someone once said with these kits that if something does not fit work out what you did wrong, it will not be Tamiya San's fault. This is very true, I wondered why I had all that sanding to do on my last build in the final fittings. Now I know and have not made that mistake again.....
