Fleet Air Arm Corsair II - Tamiya 1/32
  • colin m
    • 8804
    • Colin
    • Stafford, UK
    #16
    Originally posted by BarryW
    silver pencil
    Silver pencil. Do tell. I love it when you throw something new (well to me anyway) into the modelling arena. I bought one of those chrome pens you mentioned recently. Very impressed with that.
    • BarryW
      • Jul 2011
      • 6032
      #17
      LOL Colin. A prismatic silver pencil, nicely sharpened is good for creating metal chips and scratches. The Uschi powders are also good for that and also creating worn painted metal look. I find using both in combination quite effective.
      I will post some pics when I get the chance but it might not be until Monday or Tuesday.
        Good model Barry, wish I can make models like you. . See my Corsair below. All in 1/48.
        • Dave W
          • Jan 2011
          • 4713
          #19
          I should add that again I did not get very far with the fabric seat belts and they are binned in favour of the Eduard Steel set.
          I think I might still have a set or two of these tucked away with some of my stash and I will give them a go. Maybe I will get at least one set made up.
          One thing I will never do is waste my money on buying fabric seat belts again whether Edward, HGW or whatever. Life is too short.
          The first set of fabric seat belts i bought i ended up binning. The instructions said to screw them up into a ball. Then i tried threading the buckles on and the belts delaminated.I probably miss read the instructions and should have put the buckles on first. The next set i didnt screw up(!) and i managed to put them together. But they were so fiddly and time consuming i havent bought any more. I use the standard Eduard belts. I have yet to try the steel ones.
          • BarryW
            • Jul 2011
            • 6032
            #20
            That looks pretty good to me Kairasp...
            • BarryW
              • Jul 2011
              • 6032
              #21
              Colin - Just notice I said Prismatic - It should have read Prismacolour.... autocorrect, no doubt!
              • BarryW
                • Jul 2011
                • 6032
                #22
                I worked on the interior with the silver pencil to make the detail pop a little more and add some additional scratched and chips.
                here is what a couple of pieces looked like after - not sure how well it will show in the photos..
                [ATTACH]287342[/ATTACH]
                [ATTACH]287343[/ATTACH]
                I then brought the various sub-assemblies together.
                [ATTACH]287345[/ATTACH]
                [ATTACH]287344[/ATTACH]
                [ATTACH]287346[/ATTACH]
                [ATTACH]287348[/ATTACH]
                [ATTACH]287347[/ATTACH]
                [ATTACH]287349[/ATTACH]
                I tacked the fuselage halves together with tape and drops of Mr S Cement, keeping it well away from the tape.
                [ATTACH]287351[/ATTACH]
                After 15 minutes I removed the tape and ran the Mr S Cement along the seam.
                [ATTACH]287352[/ATTACH]
                [ATTACH]287350[/ATTACH]
                Tonight I will treat the seams.
                  Awesome work, Barry!! Looking forward to the "Rollout"!!!!
                  • BarryW
                    • Jul 2011
                    • 6032
                    #24
                    Last night I ran a bead of Mr Dissolved Putty along the seams, after half hour and it had shrunk back a bit, I did it again. Tonight I will sand it down and rescribe once I am happy with the join. Sometimes it needs two treatments in places. I love the Mr Dissolved Putty, it is very thin and very self-levelling and gets right into small cracks and joins. It is great for helping 'level' a rough surface, if you get glue finger marks for instance, a spot of this and a light sanding once cured is the best and easiest correction to make.
                    [ATTACH]287440[/ATTACH]
                    After that I spent what time I had left preparing some pieces and starting the engine build.
                    [ATTACH]287441[/ATTACH]
                    • colin m
                      • 8804
                      • Colin
                      • Stafford, UK
                      #25
                      Looking great Barry. that pencil looks a very useful addition, nice effect on the 'pit.
                      • BarryW
                        • Jul 2011
                        • 6032
                        #26
                        I treated the seams, attached some panels and the engine firewall.
                        I did have a small problem with the sanding stick slipping and grazing the front of the pit just behind where the windscreen will be. Easily rectified, I sanded it down and painted it black. You can see the dead flat black in the pic just after I painted it, handbrushed with Vallejo black. Tonight I will spray some semi-gloss varnish then dry brush. Pulled together a few more engine parts as well. The engine panels will be fixed in place so I will be painting that area with what will be seen in mind.
                        [ATTACH]287510[/ATTACH]
                        • Steve Brodie
                          • Sep 2014
                          • 4652
                          #27
                            • 22788
                            #28
                            Great work as usual Barry. Awaiting the next updates.
                              Nice going, looking awesome!
                                Barry, what is your preferred method of applying Mr Dissolved Putty ?
                                Watching this build with interest.
