GPM B-17 Flying Fortress 1\33 card kit
  • stillp
    • 8105
    • Pete
    • Rugby
    #16
    I was very impressed by the table of paper and card models at the Brampton IPMS show last weekend. Didn't think such detail was possible.
    • Bigfoot57
      • Jun 2015
      • 1103
      #17
      Peter you have a fellow builder in card I have 4 monsters to be built but like you I dont know where they are going to go
      I have a B29 and bell x1 and a B52 and X-15 you can probably already see where they are going and to finally put the nail in the coffin so to speak a Vulcan BMK2 and SR71 all card and all 1/33 scale + 4 1/200 Hindenburgs each nearly 4ft long when they are built
      One question have you used the kit parts or have you supplemented with them with additional card / plywood struts I will be following this one closely to see how you get on and hopefully pick up some tips on the way
      Card is a very underated source where in actual fact some superb models easily rivalling convential kits and costing substantially less can be produced
      Regards
      Colin
      • peterairfix
        • Jul 2012
        • 11083
        #18
        Regards
        Colin
        At the moment I have put this on on the back burner for the time being as my heart is not in it.
        • scottie3158
          • 14247
          • Holbeach
          #19
          Peter,
          Sorry to hear that it was a great looking build. Hopefully you will continue with is soon.
          • peterairfix
            • Jul 2012
            • 11083
            #20
            Peter,
            I just probably bitten off more than i Can chew
            • peterairfix
              • Jul 2012
              • 11083
              #21
              I am going to revive this thread with a completely new build as the original has been trashed with the constant moving about from draw to draw
              So here's the first part of the build and it benefits from laser cut frames. Click image for larger version
ID:	1146599Click image for larger version
ID:	1146600Click image for larger version
ID:	1146601Click image for larger version
              • peterairfix
                • Jul 2012
                • 11083
                #22
                One cockpit finished it seems to be going better than the last one. Click image for larger version
ID:	1146647Click image for larger version
ID:	1146648Click image for larger version
                • Bigfoot57
                  • Jun 2015
                  • 1103
                  #23
                  I’ve got loads of these types of models including a B17 so will be watching this one see any tips you have
                  Regards
                  Colin
                  • Defiant911
                    • Feb 2020
                    • 640
                    #24
                    This is taking shape well, utterly amazing how a few bits of cardboard can create such a great and detailed model. I’ll watch this build with interest.
                    • peterairfix
                      • Jul 2012
                      • 11083
                      #25
                      Going a bit better this time around as I have got the hang of this build so I have added another section and body work on and now started on the bomb aimers position.Click image for larger version
ID:	1146810Click image for larger version
ID:	1146811Click image for larger version
ID:	1146812Click image for larger version
ID:	1146813Click image for larger version
                      • peterairfix
                        • Jul 2012
                        • 11083
                        #26
                        Top canopy is complete and glazed and I have added the tail section and tail wheel. Click image for larger version
ID:	1146970Click image for larger version
ID:	1146971Click image for larger version
ID:	1146972Click image for larger version
ID:	1146973Click image for larger version
                        • peterairfix
                          • Jul 2012
                          • 11083
                          #27
                          Tail and rear wing constructed and installed Click image for larger version
ID:	1147019Click image for larger version
ID:	1147020Click image for larger version
ID:	1147021Click image for larger version
ID:	1147022Click image for larger version
ID:	1147023Click image for larger version
ID:	1147024Click image for larger version
                          • peterairfix
                            • Jul 2012
                            • 11083
                            #28
                            Started on the the main wings they come in three parts so I have done the first two nearest the fuselage. Click image for larger version
                            • peterairfix
                              • Jul 2012
                              • 11083
                              #29
                              I have just spent the most of today building the lower ball turret witch is where I stumbled on the last attempt. Click image for larger version
ID:	1147180Click image for larger version
ID:	1147181Click image for larger version
ID:	1147182Click image for larger version
                              • peterairfix
                                • Jul 2012
                                • 11083
                                #30
                                All wings attached and looking like an aircraft and I have started the starboard outside engine nacelle.
                                And after this one and my bismarck and titanic are finished no more card models Click image for larger version
ID:	1147255Click image for larger version
ID:	1147256Click image for larger version
ID:	1147257Click image for larger version
ID:	1147258Click image for larger version
