Revell 1/32 HE 162
    Revell 1/32 HE 162
    Started this Revell 1/32 He 162 VolksJager.
    The engine is nicely detailed, I played abot with alclad pale burnt iron and burnt iron to give the different colors to the engine's "hot section"
    Not sure if it will even be visable after engine is colsed up.
    . by Theunis van Vuuren, on Flickr
    Theuns
    Turbine wheel and impeller with pinwash and silver drybrushing
    Now that the engine is all joined up, I need to paint it and then do all the wiring and fuel pipes ect.
    Theuns
    • PaulTRose
      • Jun 2013
      • 6460
      • Tattooine
      this should be good, one of my fave aircraft
      Per Ardua
        Heat staining on the hot section.
        Theuns [ATTACH]288646[/ATTACH]
          • 22770
          Nice one Theuns, nice start.
          • colin m
            • 8741
            • Colin
            • Stafford, UK
            I always find it quite satisfying, making metal out of plastic.
              I had some PE bits and added Tamiya tape with "shade" watercolors for seatbelts, seatpan was scuffed with hairspray method.
              The BMW was dressed up with some more fuel lines and electrical looms.
              Theuns
              • Bigfoot57
                • Jun 2015
                • 1101
                Great job all round the seat looks incredibly uncomfortable did they bring their own cushions to sit on
                Regards
                Colin
                  That seat pan was designed to take the parachute pack that they sat on. Still pretty hard to sit on for long time...
                  • PhilJ
                    • May 2015
                    • 1145
                    Good start on this Theuns like what you've done with the engine
                      • 22770
                      Just caught up on this one again Theuns, and some great work.
                        Ta, it has taken a bit if a back seat while I try to complete my Mirage 3 RC for test flight this or next weekend.
                        I got most of the cockoit completed for the 162, just need to join up the fuselage, when this is dome 70% of the work is done, painting should go quite fast on this one.
                        Theuns
                          Cockpit done, ready to button up the fuse.
                          Revell 1/32 HE 162 by Theunis van Vuuren, on Flickr
                          Pitty most of the nice nose wheel detail will not be visable :-(
                          Theuns
                            • 22770
                            But we know its there, and it looks very good theuns.
                            • colin m
                              • 8741
                              • Colin
                              • Stafford, UK
                              All looks great. I'm not sure about sitting with my legs wide open and a bloody great nose wheel in between them. It's almost like the poor pilot was an after thought.
