Another HGW failure. When I was unable to get their fabric seatbelts to work I thought I could at least make use of the canopy masks in the set.
Well, the canopy masks are no use at all.
They comprise of an inner and outer set, something I consider to be an overkill. Well here is the set.
[ATTACH]290965[/ATTACH]
You can see that I removed a piece from the ‘outer’ set of masks. Well it did not fit. Indeed I have placed it beside the Tammy masks to compare and, for good measure put the ‘inside’ element next to it as well. You would expect of course the inner one to be smaller but the outer should be the same size as the Tammy.
[ATTACH]290967[/ATTACH]
I did not bother to try the other elements in the set. I threw the HGW masks away and used the ones supplied by Tamiya instead.
Do not bother with HGW products. Clearly the issues with this brand is not limited to the difficulty in putting together their fabric seatbelts, they are incapable of actually supplying masks that fit. Perhaps the failures with their seatbelts is not all down to me.
