Return to a stalled build
  • Bigfoot57
    • Jun 2015
    • 1103
    Greetings peeps
    Here is my next attempt on the modelling front I actually started this 3 years ago and shelved it after a disastrous loss of parts and interest namely all the engine throttles etc
    Anyway I have acquired some replacements so now it is time to restart this build namely Hatchett’s 1/32 scale Lancaster BMk 1 if I’m not mistaken here’s where I got to last time
    Regards
    Colin
  • BarryW
    • Jul 2011
    • 6029
    Thats a big 'un Colin...
    Never heard of that make before, balsa I assume?
    I hope that you have an aircraft hanger to display it....
    Looks an interesting and different one, I will certainly follow the build.
    • Bigfoot57
      • Jun 2015
      • 1103
      It certainly is made from laser cut plywood plastic metal and the dreaded pe but just look at the size of those instruments which have to be glued into place
      last time I tried this was a disaster so will need to think this one through this time around
      • Bigfoot57
        • Jun 2015
        • 1103
        Here’s the rest of the magazines left to finish off one of 2 things the model or me hopefully it will be the 1st option
        Regards
        Colin
        • Bigfoot57
          • Jun 2015
          • 1103
          1/32 Lancaster Build Update 1
          Made up another part of the fuselage over the weekend and refitted fuel tanks and straps back into the wings. Fuselage part string on one side at the moment and it has had a lot of damage repair work done after stringing the other side hopefully tonight it will get a coat of paint
          Regards
          Colin
            • 22771
            Coming along Colin, I will keep popping in on this one.
            • flyjoe180
              • Jan 2012
              • 12429
              • Joe
              • Earth
              Looks good so far Colin. I don't envy the task ahead but the result should be very impressive and well worth the wait.
              • Bigfoot57
                • Jun 2015
                • 1103
                1/32 Lancaster Build Update 2
                2nd phase of the fuselage build complete all stringers in place waiting for the glue to dry then it will be painted in light green colour
                I believe this one will join the centre section where the wings fix to to and the underside of both will form the bomb bay
                Regards
                Colin
                • Bigfoot57
                  • Jun 2015
                  • 1103
                  1/32 Lancaster Build Update 3
                  Fuselage now painted looks a bit rough but the ends can be sanded smooth as they will but up against other parts and won’t be seen as such
                  Regards
                  Colin
                  • Bigfoot57
                    • Jun 2015
                    • 1103
                    1/32 Lancaster Build Update 4
                    Just a photo showing a rough assembly of parts so far to illustrate the size of this thing there is a Humbrol paint tin by the nose for comparison
                    Regards
                    Colin
                      • 22771
                      That is going to be BIG Colin, nice work so far. Keep the updates coming.
                      • Bigfoot57
                        • Jun 2015
                        • 1103
                        1/32 Lancaster Build Update 5
                        Started assembling the bomb bays when they have hardened and set they willl be painted matt black the same as the rest of the bottom of the aircraft have also cleaned up the fuel tanks and straps
                        Regards
                        Colin
                        • Bigfoot57
                          • Jun 2015
                          • 1103
                          1/32 Lancaster Build Update 6
                          Bomb bay assembly complete prior to painting looks ok should align when the fuselage assemblies are joined together
                          Regards
                          Colin
                          • Bigfoot57
                            • Jun 2015
                            • 1103
                            1/32 Lancaster Build Update 7
                            Bomb bay painted black more bits of fuselage done looks like the rear end as there is a crew access door way in the right hand side and the 1st trailing edge
                            Regards
                            Colin
                            • colin m
                              • 8763
                              • Colin
                              • Stafford, UK
                              Good heavens. It will look amazing, but I'm glad it's you and not me building this.
