Well, I've made a start on this amazing kit. Opening the box was an experience, I'd already looked at a few build threads and YT vids, but I was still gobsmacked by the ooze of quality that lay before me!
I'm building this OOB, with the one exception of a resin seat - a CMK one that was £3.95. I've decided not to weather it heavily, just subtle wear and tear, and will be painting it as the aircraft of Tsuguo Matsuyama, from the carrier Hiryu, which leads me to the only real anomaly of this kit, the main colour specified on the paint call-out is clearly a bit askew! Now, call me mr picky, but I reckon anyone who is prepared to shell out upwards of £80 - £130, depending on where you buy it, for a kit, is prepared to mix their own paint. Indeed, it is demanded for the Ayotake surfaces and there were paint mixes called out for my previous build - F4 - but more on this later!
I'm following the instructions to the letter, can't afford to balls this one up...
[ATTACH]290858[/ATTACH]
[ATTACH]290857[/ATTACH]
So I've painted the insid of the fuselage as per, and then went on to the cockpit, which is a pretty complex project on its own, but perfect fit and a pleasure to build!
[ATTACH]290854[/ATTACH] [ATTACH]290853[/ATTACH]
This is now weathered and fitted from underneath to the fuselage, no drama so far!!
[ATTACH]290859[/ATTACH]
Now onto the tail control surfaces...
