Got the Tamiya 1/48 Lancaster for Christmas
    Hi there
    Wife and kids bought me the ridiculously pricey Tamiya 1/48 Lancaster for Christmas.
    I have never built a Tamiya model before and the colour schemes in the instructions are not great as I know nothing about Tamiya paints.
    Does anyone know of a link to a picture that shows the colour scheme for Humbrol paints........or does anyone have advice on which colours are best as I find that peoples advice can be different to the intructions sometimes.
    Happy christmas to you all.
    Hi and welcome!
    Just pulled this from my paint conversion Excel chart and the data is from Humbrol so it should be pretty accurate.
    Tamiya Humbrol
    X1 21
    X10 53
    X11 11
    X12 16
    X13 52
    X14 48
    X15 38
    X16 68
    X17 200
    X18 85
    X19 140
    X2 22
    X21 49
    X22 35
    X25 1325
    X26 1322
    X27 1321
    X28 80
    X3 15
    X4 198
    X5 3
    X6 18
    X7 19
    X8 69
    X9 10
    XF1 33
    XF10 98
    XF11 75
    XF12 64
    XF13 116
    XF14 147
    XF15 61
    XF16 11
    XF17 104
    XF18 96
    XF19 167
    XF2 34
    XF20 126
    XF21 65
    XF23 65
    XF24 123
    XF25 31
    XF26 88
    XF27 91
    XF3 99
    XF4 81
    XF49 26
    XF5 105
    XF52 29
    XF53 128
    XF54 140
    XF55 110
    XF56 56
    XF57 168
    XF57 30
    XF59 63
    XF6 12
    XF60 83
    XF61 30
    XF62 66
    XF63 67
    XF64 160
    XF65 116
    XF66 106
    XF7 153
    XF71 78
    XF8 25
    XF9 73
    I can't do tables here so it's not pretty looking but you should be able to lookup the Tamiya paint code and pick the Humbrol equivalent to the right!
    • peterairfix
      • Jul 2012
      • 11074
      Or try this one always found it helpful.
      And welcome to the forum.
        Not a built out the box by no means as all the whistle and bells have been added and corrected the well known faults with the kit
        DSCF0003 by peter, on Flickr
        and heres a pic were I have pointed out what was done to make the Lovely Lou version
        Lancaster_new by peter, on Flickr
          Wow, that's gonna be huge!!
            Hi Peter
            Thanks for the above.
            Which green and brown did you use for yours?
            Also, is there a problem with the decals in the kit?
              Hi [COLOR=rgb(0, 0, 0)]navalpenguin[/COLOR]
              Humbrol 29 Matt Dark Earth & Hu: 116 Matt US Dark Green, bearing in mind this model has had a 'dirty treatment' done to the finish. As to the decals there is a major problem with the roundels for the wings, they are far two small, walkway lines should run up to the roundel and as you can see on the kits they don't, in fact I think the roundel should be for the Manchester. A set of RAF roundel decals from Hannants sorted this out and a custom logo made for the name. Also as pointed out if you try and build 'Lovely Lou' the size is way to big and the wrong font is used for front nose codes is wrong and the code was a different size from each other. I have added some pics so you see what I mean, just bear in mind this model had a great deal of work and extras fitted and then my style of photography, but I hope you like it
              Peter
              10924160_921683704518554_9158280474909060895_o by peter, on Flickr
              DSCF0018 by peter, on Flickr
              DSCF0054 by peter, on Flickr
              DSCF0038 by peter, on Flickr
              DSCF0036 by peter, on Flickr
              and now the bad news "Space" 1/48 up along side 1/72 :smiling3:
              20150609_105446 by peter, on Flickr
                Hi Peter
                Thanks. That is a cracking couple of models there. Why the hell do the model companies make such basic errors. For a kit that costs as much as the Tamiya 1/48 Lancaster you would think it would be almost perfect.
                I thought I was a real aircraft buff...but before I got this I had no idea that the Lancaster only had one pilot......huh??
                When you came to paint it (I hand paint) I was wondering about the windows that line the top of the fuselage. I have painted them a dark green before I put them into the fuselage, but when it comes to painting the outside.....did you have cover each with a tiny bit of tape and then pain it?
                I notice in your pic that you have a B17. Is that the 1/48 Revell model? I tried that and gave up. I found it really furstrating. I just couldn't paint the ball turret at all.
                  First Lovely Lou didn't have windows so the kits windows were filled using plasticard. I use a mask if ever I need to have windows. As you say for the price of the kit, it's annoying to have these errors. You wait and see when it comes to the cockpit controls, this is four engine craft, so why have they only allowed for three throttles ???????. Of corse theres no problem if you go with PE parts.
                  x3 by peter, on Flickr
                  and yes the Revell B17
                  20170815_120810_HDR-2 by peter, on Flickr
                    Originally posted by navalpenguin
                    Hi Peter
                    Tamiya decals are dicey to say the least. Their 1/48 kits' decals are mostly horrendous. Grab yourself an AM set of decals and save yourself some grief. They tend to shatter on contact with water and a paintbrush when positioning them.
                    Also, a word of warning. While a wonderful kit, this is one of Tamiya's older kits, and does not have it's shake and bake characteristics. Also, it has raised panel lines that make weathering harder.
                    However, you'll have tons of fun with it.
                    Humbrol enamel is probably the wiser choice if you're going to hand paint. Tamiya acrylics are for airbrushing.
                    Cheers, John
                      Hi Fellas
                      Thanks for all the advice. Does anyone have a link that will take me to somewhere I can buy a full set of decals that are correct that also has instructions on where they should go?
                      Thanks
