Tidy - what a slur on my character, I give you THIS. Actually, that's not looking too bad.
[ATTACH]294007[/ATTACH]
A little test fit of the fuselage, doesn't look much like a Corsair.
[ATTACH]294008[/ATTACH]
Under carriage nearly assembled.
[ATTACH]294009[/ATTACH]
And then a bit of paint / weathering. You can probably guess, this is going to be a well worn machine.
[ATTACH]294010[/ATTACH]
And then some larger bits, ready for the big push. The cockpit isn't actually glued in. There's about 7 different connections between the fuselage halves, so I left the 'pit floating to make things easier.
[ATTACH]294011[/ATTACH]
