Revell 1/32 Arado Ar196 B
  • Vaughan
    • Apr 2011
    • 3174
    We'll this will be my next build. This is the mono float version having built the twin float version in 2012. It was going cheap at my LMS and I really enjoyed building the first one. I gather there is a resin canopy available so I might buy one as that's about the only flaw with the model, will have to see how much money there is in the purse.
    [ATTACH]297047[/ATTACH]
    • 22770
    Nice one Vaughan.
    • flyjoe180
      • Jan 2012
      • 12397
      • Joe
      • Earth
      Looking forward to this build Vaughan
        this is meant to be revell's best kit... looks good
        • Vaughan
          • Apr 2011
          • 3174
          Yes I think it is considering it was released in 2014 it still holds up well. The only slight niggle is the moulded on seat belts.
          I've made a start this afternoon not really following the instruction sequence so have put the main float together and built the base. Float is just sat there so the stays are in the right position for glueing. As with the twin float version there needs to be plenty of weight at the front and for this float you need 50g. I'm going to be using liquid gravity which works really well you just pour it into the cavity and then fix with super glue or epoxy resin. Have also made a start on the internal frame work all a dry fit at the moment.
          [ATTACH]297068[/ATTACH]
          • Vaughan
            • Apr 2011
            • 3174
            A small update the front section of the float has been filled with 50g of Liquid Gravity and the top of the float has been glued in place. I have purchased a set of HGW harnesses from Hannants,
            this one comes as a twin set one for this build and the other for the A variant that I have in my stash. They are not laser cut so will have to take care when cutting out. I've also made a start on the radial engine this has to be one of the best detailed engines that Revell has produced.
            [ATTACH]297206[/ATTACH]
            [ATTACH]297207[/ATTACH]
            [ATTACH]297208[/ATTACH]
            [ATTACH]297209[/ATTACH]
            [ATTACH]297211[/ATTACH]
            • Gern
              • 9213
              That Liquid Gravity looks just like small lead shot. Is it?
              • Vaughan
                • Apr 2011
                • 3174
                I'm not sure if it is, it says that it's non toxic on the bottle so presume its not made of lead. Anyway it works a treat.
                [ATTACH]297212[/ATTACH]
                • Gern
                  • 9213
                  I've just had a quick look. The stuff you have is priced at about £10 for 240 grammes on ebay. Check this out:
                  That means the modelling version is about 6 times more expensive!
                    • 22770
                    Nice work so far Vaughan
                    • flyjoe180
                      • Jan 2012
                      • 12397
                      • Joe
                      • Earth
                      Vaughan, nice clean work so far.
                        • 18266
                        Or for a fiver more (plus post of course) you can get 5kg!
                        This is looking very nice so far V. Making me want to start my one!
                        • Vaughan
                          • Apr 2011
                          • 3174
                          It's been a couple of week but guess what back in hospital again only overnight this time (last Thursday with a ride in an ambulance) all well now just waiting for an MRI in July Doc says I will last that long...HaHa.
                          Anyway I have made some progress today spraying various parts. Again not sticking to the order of the instructions. Main float and wing floats have been primed and then Vallejo Metal Color applied. This paint is really good goes on like a dream dries in five minutes and gives fantastic results. Fuselage side walls sprayed RLM 02 along with the seat assembly. Floor pan yet to be sprayed. I have also started on the wings I'm going to opt for wings in flight mode so have attached the stays which are very strong and set the correct dihedral. Radial engine sprayed too this is a really enjoyable build.[ATTACH]298999[/ATTACH]
                          [ATTACH]299000[/ATTACH]
                          [ATTACH]299001[/ATTACH]
                            • 22770
                            Very nice work Vaughan.
                            • rtfoe
                              • 9082
                              Very nice and neat Vaughn.
