Further progress rigging is almost complete front section done. Rear section waiting for the super glue to set. All a bit of fiddle but will be worth it in the end.
Just seen this Vaughan. This is one 1/32 that Revell got right, a really good kit but watch out for the canopy, it is quite a tricky construction. You have done a great job so far....
Barry it's a great kit and even though I built the two float version back in 2012 I still remember that the canopy was a real pain. I was looking into buying the resin version but Allycats models doesn't have it in stock and could be several weeks before they do. Rigging is complete not perfect, tension was difficult to maintain but it will pass.
I see you used fishing line for the rigging. I found that a good way to tighten the rigging after the fact is either a jos stick incense stick, or in my case a wooden cocktail stick. The first just smoulder and the heat it just enough to make the monofilament draw tight. Cocktail stick? Light it, blow it out and just use to warmth from the ember.
What ever you do, make a few test rig's across some empty sprues. Its a good way to get a feel for how close you can go and how much slack you can shrink back. As can be expected the longer the line the more it can take.
You might be surprised over hoe much deflection you can get when pulling them this way.
Thanks Paul. I've given up the HGW belts and have ordered some Eduard pre painted PE belts from Hannants should arrive in the next couple of day and then I will get round to closing that fuselage.
Belts arrived today hopefully I will have better luck with these. Still a bit of a fiddle but easier to thread the buckles and some belts are pre assembled. wish me luck.
