Looking very nice indeed, the paint finish on the wings is excellent :thumb2:
Revell 1/32 Arado Ar196 B
Thanks guys. I've managed to find some more time for the Arado. This afternoon I have undercoated and top coated with light olive. I have yet to start on constructing the canopy. I was hoping to buy the resin version from Ally Cat Models but it's still not in stock and it's the only one made, so there's no alternative. Anyway here's some images of where I'm up to. Still a way to go but progress is being made. It will be a year round on the 12th of April so I do need to get this one finished!!
Paul thanks, the issue with the canopy is that it is made up of of several parts and unfortunately you can see the joins that have internal tabs. The only way round this is to mask the framework extra wide to cover this up here's the canopy I built back in 2012. It looks fine but I thought I would give the resin one a go, plus it's also bit of fiddle to construct them. The resin version is cast as one so there's no problem with the framework. All the decals are complete just the rudder to mask and spray red and a decal of a swastika this one needs to be on a white circular background I have various sizes from Xtradecal.
Still no news from AllyCats re:- the canopy so I've made a start on the kit canopy. As I said before the canopy is broken down into nine parts that have to be glued together and held at the right angle this was done in situ on the fuselage. The first two sections can be done on the fuselage but the last section which the middle section slides over is better glued and taped and then sat inside the sliding section to guarantee a perfect fit. Once this last section has set (24hr) I can then start the painting process. This a bit of a drawn out process but this is the only way I've found works.
Allycats now have the resin canopy back in stock a bit late for my build as I've already completed and attached mine. I have ordered one that also includes canopy masks and decal masks, which I can use on the two float version that's in my stash. It might be a while before I build it but at least I have one.
