Hi everyone,
Like many of the ex.MM guys I too have a running project.
Started as my last entry in the now defunct RAF100GB, she wasn’t destined to finish in time anyway so it’s ok to restart over here, the tread that is not the whole build…:tongue-out3:
Right, started in the usual manner office and bang seat first.
Used Eduard FE643 on her, although designed for the Kitty hawk kit with some modification the bits will fit:
[ATTACH]297898[/ATTACH]
[ATTACH]297899[/ATTACH]
[ATTACH]297900[/ATTACH]
Think this one is a re-pop from the old Airfix kit and the age shows with lots of filling and sanding required:
[ATTACH]297906[/ATTACH]
Since the area around the bang seat is pretty busy, I added some 0.75mm & 1mm styrene rod for tubes and wire bundles with some thin copper wire for the smaller cables:
[ATTACH]297907[/ATTACH]
Office all painted up:
[ATTACH]297908[/ATTACH]
Some more add-ons, AM-48-057 pitot tube and AOA probe on the side.
The pitot’s (I think) from the kit were thinned and the pointy bit was replaced with Albion 0.3mm brass tube:
[ATTACH]297912[/ATTACH]
With a general lack of detail in the wheel wells and landing gears, I added some bits to let her look a bit more like a Jaguar.
The white parts are Evergreen sheet (0.25mm), rod (0.75 & 0.5mm)and strip (0.25x05mm)with copper wire in between:
[ATTACH]297916[/ATTACH]
[ATTACH]297917[/ATTACH]
[ATTACH]297919[/ATTACH]
Also modified the gun-vents, by installing Albion 1x0.8mm brass tube instead of the shallow holes the kit provides:
[ATTACH]297921[/ATTACH]
Just started the painting process with the inside colour of the canopy on:
[ATTACH]297922[/ATTACH]
Thanks for looking in and comments are naturally welcome.
Fernando
Fernando
