Dave Ws Trumpeter 1/48 Mig-21MF
    Having recently done some WWII Russian machines, I've decided to go on to some Cold War jets - this is going to be the first
    [ATTACH]298517[/ATTACH]
    This appeared on discount in quite a few shops, so it has ticked one of my boxes.
    No sprue shots - I would say you can see these on the Trumpeter website, but it appears to be down at the moment.
    Anyway construction started with the nice little ejection seat
    [ATTACH]298518[/ATTACH]
    Just added some seatbelts ( generic, from my spares box! )
    And the cockpit in the horrible colour that the Soviets used ( relaxing - in a Mach 2 jet? ). I used Vallejo Model Color Emerald. The decals were applied using Humbrol Decalfix
    [ATTACH]298519[/ATTACH]
    There are a lot of colour variations on the Mig-21, the wheel wells/UC doors can be green, grey, blue - it doesn't seem to follow any pattern - I'm going to do mine in light grey.............. It's my intention to do an overall metal finish. I've never had much success with this, but with more modern paints - I'm giving it a go.
    As a base, I've got ICM PAG-14 concrete slab runway parts
    • 22771
    A very nice start Nigel/Dave.
    Not sure which name to use, and welcome to the forum.
      Hi Dave good start, I'll keep an eye on your progress.
      • rickoshea52
        • Dec 2011
        • 4076
        • Rick
        Nice start, Russian turquoise is a lovely shade, right?
        We had a Mig-21 GB/SIG in 2016 - take a look here fore some ideas and tips - http://www.scale-models.co.uk/forums...he-mig-21.282/
        • PaulTRose
          • Jun 2013
          • 6475
          • Tattooine
          i did read somewhere they painted cockpits that colour cos after lots of research they found it was the most relaxing colour in a stressful environment
          Per Ardua
          • rickoshea52
            • Dec 2011
            • 4076
            • Rick
            Or disguised the puke!
            • Fernando N
              • 2448
              Nice looking office Dave:thumb2:, I'll follow along too.
              Fernando
                It was a toss up, whether I got the Eduard Mig-21, or the Trumpeter - at the time, the Trumpeter won ( by about ยฃ1, I think! ). I see that Revell are issuing a rebox of Eduards' Mig-21SMT it will be interesting to see the price compared to the Eduard 'Weekend' version.
                  Fuselage closed up - no dramas, you just have ensure that all the tabs fit into the slots! I added the wings and tail - just a touch of filler....................[ATTACH]298786[/ATTACH]
                  You can see that all the control surfaces are separate, I'll leave those off until much later. Since I'm going to do a metal finish, joint preparation, and seam finish will be critical - as every flaw will be highlighted.
                  The model is going together quickly, a simple model of a simple Soviet jet - no gimmicks or frills!
                  • JR
                    • May 2015
                    • 18273
                    Nice Dave.
                    Office looks good.
                    Will follow from the back and let the wingie lovers in the front . John
                      • 22771
                      Looking very nice Dave.
                        All the scoops, fences, pylons etc added, and primed with my new go-to primer, Grey Ultimate Primer................[ATTACH]299013[/ATTACH][ATTACH]299014[/ATTACH]
                        All apertures were filled with damp tissue paper, and masking fluid to give a seal. As was to be expected,the primer showed a few paces that need attention...........
                        Although the instructions don't say it - I added weight in the nose, using 5 min epoxy, and 4mm ball bearings. It may not need it, but I don't want a tail sitter.
                        The base is under way - The ICM 'PAG-14 Airfield Plates' gives you 32 tiles to be butt joined in any combination. This is 4 X 3, the MIg-21 isn't that big.
                        [ATTACH]299029[/ATTACH]
                        Overall primed, then the centres of each panel darkened, I'll run a few washes over the joint areas, and maybe a few oil stains
                        • JR
                          • May 2015
                          • 18273
                          Dave looking good with the primer.
                          What do you think to it,?
                          I only found it last month on the Ultimate site and the first time I used it was on the Kitten. Sprays beautifully, had to use a . 4 needle . There's a good artical on
                          https://www.scalemodellingnow.com/tb...ltimate-primer. Which you might have seen, for those that haven't it goes on to use the Black version and talks about using Alcad2 metallic finish .
                          John .
                            John,
                            I had used Vallejo primer for years, but then had a/b problems with it, so gave Ultimate Primer a go - sprays beautifully, lovely fine, smooth finish. I'm not going to go down the gloss black primer route - that may be suitable for a showroom car, but not a Russian jet....
                              Touched up a few seams, and reprimed - I'm going to leave the primer to really go off overnight before spraying the metallic.........
                              As an experiment, I took one of the distinctive supersonic Mig-21 fuel tanks ( you get two, but use only one ), primed it and used AK True Metal Silver. This is a waxy paste, that you apply thinly, allow to dry, then buff up with a soft cloth
                              [ATTACH]299248[/ATTACH]
                              It comes up very nicely - bit too shiny, in fact. It's easiest to apply thinly with a finger, but also easy to get ridges/lumps, which are then difficult to get rid of. I would say it's useful for small parts ( eg hydraulic rams ), or small areas, but covering an entire plane to a consistent finish, would be very difficult. ( I could see a Knights Armour done with this stuff ).
                              Being rather waxy, it doesn't take over painting easily, you would have to give a varnish overspray, which will dull down the metallic finish, rather defeating the whole point!
