Yup, I've seen movies when the pilot remove his goggles and you can see the outline of the goggles around the eyes and the grime on the rest of the face.
I have to take my hat off to you, this is just stunning in every sense of the word and such small scale.
Really impressed with your aging tech on the prop and grain effects. Those Lewis guns are stunning too
Top marks from me.
Steve, I took a long break in between each assembly points to rest my eyes Robert, welcome aboard and glad you popped by to see me go crazy on an old kit
Now the next post will tell you why this might be a one time thing.....rigging!!!
Hi John...don't have to wait too long...but decals first before rigging...
Decals were applied first before weathering so the earlier pictures should come after this...
[ATTACH]308788[/ATTACH]
The decal sheet comes with a false step for the fuselage which looked "False" so I removed it and carved out the step. Below is the image with the decal.
[ATTACH]308789[/ATTACH]
However much decal solution I brushed on didn't soften the decal...I had to force them into the contours by gently rubbing them down. I cut it at the joint of the elevator and applied white glue and pressed it into the groove.
[ATTACH]308790[/ATTACH][ATTACH]308791[/ATTACH]
For scale comparison next to Hershey's syrup bottle.
[ATTACH]308792[/ATTACH]
Here you can see the carved step.
[ATTACH]308793[/ATTACH]
Finally the protrusion of filaments sprouting from the pre-drilled anchor points, each length calculated for its intended purpose. At first it looked like a nightmare.
Hi John, CA definitely. There are at least 28 points on the bottom wing and fuselage alone. The faster the setting the better. I usually count to five for each glue point.:tongue-out:
Thanks Joe...actually it's easier than it looks. I learnt a way to do this from a fellow modeller who does Wingnut bi-planes. Just have to figure out the connections and having the right length for each joint.
Hi, the rigging was primed with a mixture of sliver and black...the black was to dampen the shine of the silver. Then working from bottom up I glued one end as seen on previous picture, then after securing the upper wing the rigging is thread through the pre drilled holes.
[ATTACH]308938[/ATTACH][ATTACH]308939[/ATTACH]
Looks like we're having spaghetti tonight dear...
[ATTACH]308940[/ATTACH][ATTACH]308941[/ATTACH]
Then with the help of wooden pegs as weights I secured the rigging with a tiny drop of CA on the underside of the top wing.
I didn't gloss enough of the top wing for decalling...there is is still traces of silvering. I just noticed the small front canopy I made from a tablet bubble cover is slightly off center.
