I thought it was time for a change of pace. Yesterday I bought myself this kit:
[ATTACH]302824[/ATTACH]
for the princely sum of €3.75 (normally €7.50, half off due to a sale at the shop). I’ve built one of these Hobby Boss easy assembly kits before, so the contents didn’t surprise me this time round:
[ATTACH]302825[/ATTACH]
A few minutes’ work on the two main parts results in:
[ATTACH]302826[/ATTACH]
and from that we can skip to the completed model:
[ATTACH]302827[/ATTACH]
because there’s really very little in-between steps that I could show even if I wanted to
There are only three snags I could find. One is that the engine cowling is hard to fit right unless you either ream it out a bit, or file/scrape down the piece it is to go on. Another is that you can damage the propeller by taking it out of the plastic, according to a review I read. The solution is simple: use a tool to press the “bump” of black plastic at the end of one of the blades in, so the tip can pop out. Finally, like on the other kit I built, the open canopy (the kit comes with both open and closed ones) won’t fit over the rear fuselage, so that decided which one I was going to fit.
It took me all of 20 minutes to get to this stage, hence it made me think of Blackadder
Now it’s just waiting for the glue to dry so I can add some paint.
