Dave Ward's 1/48 HB FJ-4 Fury
    • 18901
    Loving the look of this one. I find the early Cold War jets to be much more interesting than the later stuff....I’ll keep an eye out for you next few builds...
    Tim
      The underside, and wheel wells etc are all white. I always have problems with spraying this, and today was no exception! Nozzle Blocking, Splatter etc. I had to add some retarder, and more water than normal ( maybe the high temp? ). A few thin coats, and it looks OK
      [ATTACH]303765[/ATTACH]
      Topside, the control surfaces have also been sprayed white, ready for masking. I used Vallejo ModelAir White for the underside. I will use Mission Models Light Gull Grey for the upper surfaces, a new maker to me. I have read good reviews on this, so I will see...........
        Progressing well Dave.
          I forgot to take pictures of the masking! The Mission Paints Gull grey sprayed OK, but didn't cover very well - I don't think that it has any advantage over any other paint that I've used.
          [ATTACH]303916[/ATTACH][ATTACH]303917[/ATTACH]
          The masking still lifted the base white coat in a few places, despite using a low tack tape - maybe I should have let the base dry for a few days, to really harden off. Next stage will be an overall gloss varnish, before decalling and a few panel washes. There won't be any weathering, USN jets of this period were always immaculate
            After an overall gloss varnish coat, I masked and painted the leading edges of the wings/tail aluminium - then onto decalling
            [ATTACH]304074[/ATTACH]
            The decals are quite thick, and the top wing star is in 3 pieces, one either side of the wingfold, and one over the top of the wing fence - which I haven't been able to get to sit down ( yet ). When I've finished the decals, I'm going to seal everything in with a Satin varnish coat
              Nice. A plane that I have to confess I hadn't heard of. Then to cap it all, War Thunder (favourite video game) are introducing the FJ-4 as well.
                The rapid development of jets produced some short lived aircraft - I'm still waiting for a modern 1/48 version of this[ATTACH]304120[/ATTACH]
                By all accounts a poor aircraft - the Vought F7U Cutlass, but what a looker!
                • Fernando N
                  • 2448
                  #23
                  Nice work Dave and fast too.:thumb2:
                  Good luck with the remaining decals.
                  Fernando
                    Oh yes. That's beautiful.
                      Decals completed - the nose decals aren't particularly a good fit, and I will have to try and match the paint to touch up. Next is a satin varnish coat & final assembly.............[ATTACH]304176[/ATTACH][ATTACH]304177[/ATTACH]
                      At this stage, my mind has turned to what to build next............ I'm going to go for a tank
                      [ATTACH]304178[/ATTACH]
                      Looks very nice, apart from the tracks - 2 part individual little links -130 of them!
                      I'll be starting this, on completion of the Fury
                        Luckily I found a good match to the blue on the nose, Vallejo Ultramarine. Undercarriage on, air brakes added. Just a few more details, like lights, undercarriage doors and the underwing stores.
                        [ATTACH]304277[/ATTACH][ATTACH]304278[/ATTACH]
                        For some reason, the cockpit canopy won't sit down properly - I'll have to sort that. I think the next pics will be in the 'completed' section!
                          • 22770
                          #27
                          That looks great Dave
                          • yak face
                            • Jun 2009
                            • 13840
                            • Tony
                            #28
                            Nice! Looking forward to the completed pics , cheers tony
                              I came to fit the undercarriage doors................HB will have you fit them all open. I thought that they looked so vulnerable to damage on carrier operations. I went on YouTube and found a video that shows that the doors were all closed on the ground, engine running. I assume that engine stopped, the hydraulic pressure bleeds off gradually, and the doors will gradually drop open ( like the P-51 Mustang, another North American product! ). Anyway, easier to fit them closed!
                                Nearly didn't finish this - I broke the pitot tube off no less than 4 times during the final stages - BP rose, and it nearly had a test flight into the bin. Half an hour and a nice latte later, the pictures are now in the 'completed' section.
                                Many thanks for dropping by, the likes and the comments!
