I am progressing well with the painting.
Underside painted white, the sides intermediate blue and she is masked up ready for sea blue.
[ATTACH]317517[/ATTACH]
I adopted my usual method of base coat application for darker colours.
First an overall application then I mix the base colour with a little white to spray into the middle of panels and in areas that would catch the light.
[ATTACH]317518[/ATTACH]
Next it all needs blending in and toning it down with repeated mist coats of thinned base coat until you get the effect that you want.[ATTACH]317519[/ATTACH]
You just have to be careful not to overdo these mist coats.
I then end with a final mist coat of Mr Levelling Thinner. This helps even out the paint and makes sure it is nice and shiny for decals. All paints are MRP of course.
here she is with some of the masking removed. The rest will be removed when I have finished the matt coats after weathering..
[ATTACH]317520[/ATTACH]
There are just a few areas where I need to touch up. The touching up will be done by airbrush using Clever Putty for local masking.
Next I will be painting details before decalling.
