Dave Ward's 1/48 Revell/ICM Mig-25 RBT Foxbat 'B'
    The instructions indicate 25g of weight as ballast. Instead of my normal load of ball bearings, I used 9 X 1p coins ( best use I have made of these! ) I rolled them in silver foil, and fastened into the nose with 5-Minute epoxy[ATTACH]314182[/ATTACH]
    Undercarriage legs assembled, and painted, I'll leave these off until I've painted & masked the exterior.
    [ATTACH]314183[/ATTACH]
    Wheels - the 2 main wheels are the largest I've ever fitted to an aircraft!
    [ATTACH]314184[/ATTACH]
    I'm going to have a think about the masking, there are 3 main colours - grey, aluminium, and gunmetal, and the order in which I do them needs consideration................
    • Fernando N
      • 2448
      #17
      Looking very nice Dave, like the office a lot.:thumb2:
      Good luck with the final assembly and paint work.
        Wings and nose finally added, the nose joint needs a bit of filler to blend in nicely. The elevators will be left off at the moment - they'll get in the way of the painting.[ATTACH]314264[/ATTACH]
        The model is a little too big for taking decent pictures on the work bench! I'll have to clear stuff away to get final pictures!
        I sprayed the rear underside & sides with Vallejo Metal Color Aluminium[ATTACH]314265[/ATTACH]
        I hope that masking over the ally paint will be OK. Dielectric panels painted dark grey, ready to be masked.
        That BIG fuel tank, also sprayed with Vallejo Aluminium
        [ATTACH]314263[/ATTACH]
        Now that the nose & wings have been added, you can appreciate what a big brute of an aircraft this really is
          I spent most of the morning carefully masking the aluminium panels etc, and stuffing paper tissues into the engine inlets & exhausts & wheelbays. I primed overall, then painted the anti glare panel black. I did a partial spray of the upper surfaces, to see how the paint covers
          [ATTACH]314445[/ATTACH]
          I'm using Vallejo Model Air 339 - Russian AF grey No.3 - it's one of those paints that has a big tone change as it dries. Next will be masking the anti-glare panel & completing the grey basecoat.
            Basecoat applied, and all the masking removed. A little bit of bleeding, and paint has lifted in a few places, so touch up will be needed, otherwise, not bad.
            [ATTACH]314487[/ATTACH][ATTACH]314488[/ATTACH]
            Next up will be the gunmetal section at the rear of the fuselage. Note: The grey on the tail fins IS asymmetrical! Getting towards a finish, not many bits left in the box..............
            • flyjoe180
              • Jan 2012
              • 12407
              • Joe
              • Earth
              #21
              Nice paint work Dave.
              • RM6239
                • May 2018
                • 343
                #22
                Looking good Dave.
                cheers
                Ross
                  • 22770
                  #23
                  Very nice paint work Dave.
                  • Steve Brodie
                    • Sep 2014
                    • 4652
                    #24
                    looking very nice.
                      I decided to assemble the exhaust 'petals' - the inner petals onto the aircraft, and the outer petals to the final fuselage piece.......................
                      [ATTACH]314519[/ATTACH]
                      This was to allow me to airbrush the nozzles - WRONG
                      I tried to dry fit the outer petal assembly over the inner petals - not a chance. I had to remove the carefully fitted inner petals, then re-attach them after assembling the outers to the airframe - it just goes to show that the instructions are sometimes in that sequence for a reason
                      [ATTACH]314520[/ATTACH]
                      Onto tricky masking for the gunmetal rear fuselage section............
                      • wotan
                        • May 2018
                        • 1150
                        #26
                        Nice job Dave. Great inspiration for my little build.
                          Gunmetal sprayed, and masking removed. The Vallejo Gunmetal Grey was not very good to spray, it seemed to cover poorly, and when I peeled the masking off, the gunmetal had crept under! - so more touching up will be needed - so much for my careful masking
                          [ATTACH]314532[/ATTACH][ATTACH]314533[/ATTACH]
                          When all the touching up is completed, I'll seal all in with a coat of varnish, then there are a lot of decals to add..................
                          • scottie3158
                            • 14202
                            • Holbeach
                            #28
                            Dave,
                            Coming on very nicely.
                              • 22770
                              #29
                              Hi Dave after masking I usually spray the same colour again over the masking tape, so if there is a small gap the paint will fill it. That usually stops any bleed of whatever colour your using next.
                              Nice work so far by the way.
                                All sealed in with gloss varnish - rather than masking the rear of the fuselage, I used Bare-Metal Foil for the section in front of the petals
                                [ATTACH]314601[/ATTACH]
                                Canopy painted - no masking, just holding my breath......... ( needs a little touch up )[ATTACH]314599[/ATTACH]
                                I decided to do the panel washes before adding the decals, here's the wing underside without a wash[ATTACH]314600[/ATTACH]
                                And with a light panel wash..............
                                [ATTACH]314602[/ATTACH]
                                I find it best to do smallish sections, then remove excess wash with kitchen towel, wait too long, and it can take a bit of effort to clean off, too early, and you can wipe it clean out of the panel lines.
