Hi Everyone,
Here's Henry Talalla's Typhoon or near enough as he may have been shot down in a later bubble four bladed version of the rocket firing Typhoon. It is in his squadron markings, 182Sqd. The car door version was being switched just before D-Day with the upgraded bubbled canopy version and since only the CO has a constant aircraft of his own, the others would fly in anything operational and assigned to them on that day. I'm pretty sure Henry would have flown the car door version or the B1 when joining his squadron.
The kit is a Revell 1/32 scale with raised panel lines and covered with rivets. These all had to be sanded down and panel lines re-scribed. Early on I had decided I would not show the engine but one was provided that can be super detailed if one so chooses. Also I wanted to correct the wheel wells.
[ATTACH]315927[/ATTACH]
I just painted the engine black and hoped it wasn't visible in any openings. The kit wheel well sides were molded flush with the contours of the door flap. But in reality it was boxed shaped on the inside.
[ATTACH]315928[/ATTACH]
I cut away one side and proceeded to cut the other along the edge of the well.
[ATTACH]315929[/ATTACH]
Meanwhile I thought the flaps ought to shown open as well...living dangerously was I...so cut away I did.
[ATTACH]315930[/ATTACH]
Whatever was cut was replaced with plastic card...
[ATTACH]315931[/ATTACH]
Everything was mirrored for the other side....
[ATTACH]315932[/ATTACH]
The rivet impressions hide the rscribed panel lines. The kit was peppered with it...very measled like.
[ATTACH]315933[/ATTACH]
From the inside it looked like this. The boxed frames held everything in place inside the well. This also shows how thick and robust the Typhoon wings were.
[ATTACH]315934[/ATTACH]
More later...
More later...
