As the title says this one's a real challenge as I have done one before and I binned it so as my skills have improved I going to give it another go[ATTACH]319127[/ATTACH]
It's challenge time Revell 1\32 Bristol Beaufighter.
Tags: None
But now I have gained more skills I am going to give it my all.Comment
And I forgot to attach the engine pics one weathered and the other yet to be done.[ATTACH]319145[/ATTACH]Attached FilesComment
Inspiration can be found here. https://forum.largescaleplanes.com/i...comment-854118
Not that i think you lack any Peter.
Following this buildComment
Its certainly a challenge Pete , its an old timer for sure! I built one a few years back and added a full scratchbuilt interior , reworked the wheel wells to give the correct depth , added the collector ring exhaust stubs etc etc. I photographed all the build stages but the laptop I was using at the time went wonky and I lost all my photos! Ive still got the model though but unless you broke it open you would never know whats inside! I always fancied having another go at this kit but then I think of the work I did last time and it makes me think again! it does make a mighty impressive beast though so who knows ,maybe one day when ive got more time. cheers tonyComment
Thanks for all the inspiration depending on what mood I am in I might give some scratch building a go but I will be adding some belts.Comment
The two engines are weathered and finished.
Now the fun begins first up are the props and they each have a mould line, two ejecter marks and one sink mark to be sorted.
And part 13 spot the mistake between the instructions and the real peace so a bit of scratch building needed there.[ATTACH]319185[/ATTACH][ATTACH]319187[/ATTACH][ATTACH]319188[/ATTACH][ATTACH]319189[/ATTACH][ATTACH]319190[/ATTACH]Comment
