BAC Lightning F.6
), but It’s clearly not suitable for what I’ve got in mind.
It looks like the diameter I need is for sale at those links, so thanks for those, I’ll probably order from them soon.Comment
You’re not Dutch are you, given that spelling of my name?
That’s more or less the plan: get rod of the diameter I actually need instead of trying tos stretch thicker sprue down to the right diameter. I’d still like to be able to heat-form it for aesthetic reasons, though.Comment
I’ve been painting thr Lightning now. First I sprayed it silver (about a month ago), and after quite some thought on how to make it look like bare aluminium, I decided to paint random panels in silver mixed with a little bit of other colour, mainly gun metal, light grey and/or white. So far, I’ve gotten to this stage and I think it looks fairly good, though I’m not there yet:
[ATTACH]329478[/ATTACH][ATTACH]329479[/ATTACH][ATTACH]329480[/ATTACH]Comment
Thanks, good to read some confirmation that I’m on the right trackAll I need to do is paint about as many bits again as I’ve done now, and I think I can move on to the next stage (painting the tail fin etc.), then the decals.
But anyway, she is looking very nice at the moment. I like the effect of all the different panels you have created.Comment
ISTR I read a couple of reviews before deciding to buy the kit, but none of them pointed out this particular problem. Not that it would have stopped me buying it, but it would have saved me a fair amount of time trying to work out what was interfering with fit.
Damned paint incompatibility … !
I had the different panels done to my satisfaction, and painted the fin, upper nose and cockpit canopy matt black. Because I thought the finish might be a bit rough for all the decals to go onto this model (it comes with what seems like a full set of stencilling), I sprayed a coat of gloss varnish from a spraying can over it. See the result:
[ATTACH]329935[/ATTACH]
It looks like all the silver base paint wrinkled slightly, and some of the paints I put over it did so even more. The black on the canopy didn’t, but the silver below it caused the extreme chipping effect shown in the photo — that this isn’t the black paint’s fault is obvious because the tail fin looks fine.
Anyway, I’ve decided to go with it — I absolutely don’t feel like stripping the model and repainting all of it, and kind of hope that a layer of matt varnish later on will solve things.
So I then proceeded to begin applying the decals. Here’s the lines on the left wing, which is all I’ve done so far because I needed to leave them to dry before I could begin on the other side.
[ATTACH]329934[/ATTACH]
Airfix provides decals for the red and yellow bits you can see, but I felt that painting these would be simpler.Comment
