Revell 1:48 DH Mosquito B Mk IV
  • mossiepilot
    • Jul 2011
    • 2272
    #16
    Mmm, when I edited the post the picture wasn't there. So I posted again to show it. Now it's there.
    Done it twice, never mind lol
    Tony.
      • 18271
      Well that would solve the problem with the weak undercarriage. lol.
      It would make a good diorama.
        • 22771
        #18
        What a copout :laughing: only kidding but it would have been a great diorama for the from a photo GB
        • colin m
          • 8759
          • Colin
          • Stafford, UK
          #19
          Vaughan, would you believe it, I paid £14.95 for the kit ! So a nice set of metal gear would double the price of the model. I'm going ahead as Revell instruct, but will use tinfoil to mask up - and lots of tape.
          Tony, I like the wheels up landing. For the purpose of a dio, you could take great pleasure in scattering bits of landing gear around the rear of the model. That's got to be easier than fitting the things !
          Colin M....
          • colin m
            • 8759
            • Colin
            • Stafford, UK
            #20
            Looks a bit like a Mosquito now.[ATTACH]34839.vB[/ATTACH]But, I did have a bit of fun getting the pit into the fuselage, again the bulkhead seems to big to fit ? Still, all done now.
            Laurie, what stage are you at now ?
            Colin M........
            [ATTACH]39317.IPB[/ATTACH]
              Yes had the same problem Colin with the pit & fuselage. Thought it was my building ability but seems not.
              Now finished the two wings except for few odd things. Next job is to sand & fill wings & fuselage Some big gaps around the long side of both the nacelle but may be me.
              At my age my attention span is not as great as it was so not a fast builder. Also I believe like you this is my first 1/48 & there is a vast difference between that & the five 1/72 I have built in my first modeling year.
              Have to sort out which props to use. Mine also will be the Woodford (think that is the name). Any body know the significance of the different props ? One set provided is a slim Jim type the other set has really chubby blades.
              Must find time ( and courage) to sort out publishing photos of my efforts.
              • colin m
                • 8759
                • Colin
                • Stafford, UK
                #22
                Well Laurie,
                I've got the wings done and had a play with the nacelles - gaps everywhere ! As for the props, I'm using the wide ones, just because I like them. I'm fairly sure the 105 Sqn Mosquitos used the thin ones but the instructions are no help here, they don't even refer to 105 sqn !
                Colin M.........
                  Morning Colin
                  My research shows that Wooldrige took over 105 squadron from 17 March 1943.
                  !05 squadron were using the Mk 1V at that time. This from all accounts used the thin props. They continued using this Mk until 1944
                  But 105 obviously slowly upgraded in July 1943 to the MK 1X. This had a two stage engine & was equipped with heavy paddle wheel props, the fat ones. But replacement must have been a slow progress perhaps replacing losses of the MK1V rather than a complete squadron change.
                  So really we should be using the thin props. But for me as you Colin, using artistic licence, I am going to fit the paddle props they seem to fit this rugged aircraft.
                  Yes you need a lot of patience & expertise, hopefully, in bringing the nacelle parts up to standard. Worst detailing I have seen so far in my first six models never the less rewarding to get it looking OK.
                  • colin m
                    • 8759
                    • Colin
                    • Stafford, UK
                    #24
                    Nice one Laurie,
                    Well we'll never make a good pair of rivet counters will we ?
                    Colin M.......
                    • colin m
                      • 8759
                      • Colin
                      • Stafford, UK
                      #25
                      So, the wings were built and fitted (a nice tight fit) without a fuss. Then I had a play with the landing gear. As I wasn't happy about fitting them later, althought I would have normally done this, they're in place now just as the instructions say. I really didn't need to fit the wheels but just wanted to see what it was going to look like on the ground. They're coming off before spraying ! The nacelles don't fit too well. I'm not sure if I've done something wrong, or they just don't fit. Anyway, I'm going to use the stretched sprue trick on these tapering gaps. This will fill the gap and add some strength to the joint.
                      Anyway, it's really looking like a Mosquito now.
                      Colin M.....
                      [ATTACH]39470.IPB[/ATTACH]
                      [ATTACH]39471.IPB[/ATTACH]
                      [ATTACH]39472.IPB[/ATTACH]
                      [ATTACH]39473.IPB[/ATTACH]
                        • 22771
                        #26
                        Some hard work going into this one Colin but its looking good so far
                          Fascinating watching you building the same model Colin.
                          I fitted the inside half of the nacelle before attempting the landing gear. Also completed each wing first & have yet to fit the wings to the fuselage after filling & sanding each one.
                          One thing it looks as though you have fitted the tank to the landing gear. It should go on the bulkhead which as yet in the pictures you have taken is not fitted & which has a couple of fixing points for the tank.
                          Think that if I had thought enough I would have followed your build procedure. I fitted one half of the nacelle with it strapped temporarily to the other half to get proper alignment. Certainly poor fitting in that area. My poor fit was on one long side of the nacelle. I have used plastic board cut to shape & slipped into the open joint.
                          Do not forget Jericho Operation on BBC 2 tonight Colin which is all about the Mosquito.
                            • 18271
                            The Engine oil tank in the Nacelles is indeed fixed to the upper frame work of the undercarriage and not the firewall
                            This is a photo of a mossie under restoration in Canada. The upper most part of the U/C is fixed and I think the firewall is also fixed to this 'leg'. The knee is just below the tank where the diagonal brace meets it. Don't worry about the colour in the photo. Deep red is the right colour. (in most cases...)
                            If you have fixed your tank to the fire wall it might be why there was problems getting the U/C in.....
                            I think that your build is looking good. A very different way of attacking the U/C and nacelles, which incidentaly looks like the way its really done.
                            [ATTACH]39489.IPB[/ATTACH]
                              "Indeed" indeed the tank is fitted onto the landing gear. My aplogies Colin.
                              Just shows what age does for the memory as I have fitted both tanks in the correct place & only about 5 days ago. Woe is me.
                              Must find out which year I am in !
                                • 18271
                                Might I suggest some extra vitamin D lol.
                                I only pulled it up as I had seen the photos of the re-build when I was doing my mossie.
                                I was going to give it some with the lead wire and all that. How ever, once I saw just how much would actually be seen, once the legs where in, the doors on and all that, I deemed it to be a "wast of time".
