P51 D from Zoukei Mura
    Hi comrades!
    It has been a while since my last post. I even found that the whole webpage has changed!
    Anyway I have been modelling all this time, don't think I've been lazy, so I will be posting some of the models I've built.
    Here you have a superb P51 from a Japanese brand called Zoukei Mura:
    [ATTACH]322020[/ATTACH]
    The best of this model is that it has each and every little detail from the inner structure, engine, machine gun bays... you'll see.
    Even the instructions manual is full of detail, as if it was a contemporary document:
    [ATTACH]322021[/ATTACH]
    [ATTACH]322022[/ATTACH]
    Following the instructions, I started off with the engine. Just check the crazy level of detail... they even moulded the pistons!
    [ATTACH]322023[/ATTACH]
    So step by step, I built the engine block, the first part of the transmission and the intake manifold:
    [ATTACH]322024[/ATTACH]
    [ATTACH]322025[/ATTACH]
    [ATTACH]322026[/ATTACH]
    Then I glued the two cylinder blocks and the crankcase:
    [ATTACH]322027[/ATTACH]
    And here you have it alltogether, along with the propeller shaft:
    [ATTACH]322028[/ATTACH]
    On the back of the engine I glue the fuel and oil pipes, as well as other little details:
    [ATTACH]322029[/ATTACH]
    I also build the tuebocharger:
    [ATTACH]322030[/ATTACH]
    And here you have the three main parts already covered with black primer: engine, turbocharger and crankshaft cover:
    [ATTACH]322031[/ATTACH]
    Just some shots of grey primer in order to create a simple light/shadow scheme:
    [ATTACH]322032[/ATTACH]
    And then the main paintjob in a grey/blueish scheme. As you can notice, I highlited the bolts and main lines and left the cylinder cover in black:
    [ATTACH]322033[/ATTACH]
    Next step, I put a decal and applied some washes with a very dilluted mix of brown and black. I also added the water coolant tank and the alternator:
    [ATTACH]322034[/ATTACH]
    Above the engine I added the oil and fuel pipes:
    [ATTACH]322035[/ATTACH]
    Time to put it all together:
    [ATTACH]322036[/ATTACH]
    [ATTACH]322037[/ATTACH]
    And more pipework (I think these wre for the sparks):
    [ATTACH]322038[/ATTACH]
    And then I added the exhaust cover and ignition cables:
    [ATTACH]322039[/ATTACH]
    Well, it seems I only can add 20 images each time.
    Let's continue with the exhaust pipes, painted brown as if they where burnt by the exposure to heat:
    [ATTACH]322040[/ATTACH]
    With that, the main part of the work in the engine is done, so next step, will be the firewall, engine frame and oil tank:
    [ATTACH]322041[/ATTACH]
    I painted them with a tone of yellow, very similar to the imprimation they used in the North American factory:
    [ATTACH]322042[/ATTACH]
    But my dear P51 has seen many combats over the european skies, and has been manipulated by many mechanics so I put some grime to make it look a little bit more real:
    [ATTACH]322043[/ATTACH]
    I painted the oil tank in bright yellow:
    [ATTACH]322044[/ATTACH]
    And, as I'm going to place a pair of mechanic, figures, I decided to imitate an oil leakage for them to fix:
    [ATTACH]322045[/ATTACH]
    Then I glued it all together, firewall, engine and frame:
    [ATTACH]322046[/ATTACH]
    [ATTACH]322047[/ATTACH]
    [ATTACH]322048[/ATTACH]
    [ATTACH]322049[/ATTACH]
    And that's how cool it looks the Packard V-1650, the american version of the superb Rolls-Royce Merlin!
    Now, let's aim for the cockpit!
    I started with the cockpit floor. As I learned, the cockpit floor was made of wood but it was painted black, so I decided to imitate that. First, I painted the floor in deck tan, and then I gave some brush strokes with dark brown and red brown oil paints:
    [ATTACH]322050[/ATTACH]
    Then I painted with Tamiya orange glaze:
    [ATTACH]322051[/ATTACH]
    Afterwards, I covered it with future, hairspray and matt black:
    [ATTACH]322052[/ATTACH]
    And why the hairspray?? Because with a toothpick, a brush and some water I can imitate the scratches:
    [ATTACH]322053[/ATTACH]
    Then I painted the rest of the floor with interior green and I applied some dust:
    [ATTACH]322054[/ATTACH]
    I followed painting all the rest of elements also in interior green:
    [ATTACH]322055[/ATTACH]
    [ATTACH]322056[/ATTACH]
    With yellow primer and steel I paint the scrathes and marks left by the parachute hilts in the seat:
    [ATTACH]322057[/ATTACH]
    I completed the seat with dark green for the cushion, black for the upper part and tphotoetched belts:
    [ATTACH]322061[/ATTACH]
    And in the back... I glue the heating system:
    [ATTACH]322062[/ATTACH]
      Next step: I put the fuel tanks and the frame for the battery and the radio with the admission pipe and fuel indicator:
      [ATTACH]322063[/ATTACH]
      For the gauges I used the decals and some paint:
      [ATTACH]322064[/ATTACH]
      Then I painted the central console and I added the pedals:
      [ATTACH]322065[/ATTACH]
      Then I painted the sides and added some decals:
      [ATTACH]322066[/ATTACH]
      Time to bring it all together again:
      [ATTACH]322067[/ATTACH]
      [ATTACH]322068[/ATTACH]
      [ATTACH]322069[/ATTACH]
      [ATTACH]322070[/ATTACH]
      I added the radio and battery:
      [ATTACH]322071[/ATTACH]
      And that's how a mustang looks like without skin:
      [ATTACH]322072[/ATTACH]
      That will be all for today!
        • 22771
        That is looking sweet, and nice to see you posting again.
        • scottie3158
          • 14221
          • Holbeach
          That's a crazy level of detail and you appear to be doing it justice, nice work.
          • colin m
            • 8770
            • Colin
            • Stafford, UK
            You're doing a great job there with that amazing level of detail. But pistons - what was the manufacturer thinking !
            • BarryW
              • Jul 2011
              • 6029
              It is their little ‘quirk’, almost a trade mark.
              • BarryW
                • Jul 2011
                • 6029
                you are dong a great job Judas. Be careful fitting the airframe, dry fit and keep dry fitting at least two steps ahead. It is easy to get a small misalignment that has a knock on effect with this engineering. It is a great kit though.
                  Hi Barry!
                  Well, I finished this kit a while ago, but as you've said, I had some fitting problems I could manage at last (Well, you'll see)
                  Thanks anyway!
                    Let's continue!
                    I primed the pipes and elements that conect the engine with the oil and coolant radiators:
                    [ATTACH]322236[/ATTACH]
                    Then I painted them with Alclad metallics, which I think is the best option for doing metallics.
                    It has its pros as for example its supersmooth finish, but also has its cons, as it is truly revealing if any mistake during building or sanding was made:
                    [ATTACH]322237[/ATTACH]
                    Anyway I left this part like that because it has a cover, is going to be placed in the belly of the plane, and it won't be seen. Here I glued everything in place:
                    [ATTACH]322238[/ATTACH]
                    And then I add the coolant radiator:
                    [ATTACH]322240[/ATTACH]
                    And the oil radiator:
                    [ATTACH]322239[/ATTACH]
                    And just below the engine I glued the intake for the supercharger, also painted with alclad laquers and weathered with oils, Here you can also see the final conection of the coolant pipes with the tank just above the transmission and propeller shaft, which was quite tricky as it didn`t want to fit in place:
                    [ATTACH]322241[/ATTACH]
                    Then I primed the wing structure:
                    [ATTACH]322242[/ATTACH]
                    I painted the main fuel tanks:
                    [ATTACH]322243[/ATTACH]
                    At that point I knew I wanted to left open at least one of the machine gun bays and I didn't realize that the tanks couldn't be seen, but anyway it didn't took so long:
                    [ATTACH]322244[/ATTACH]
                    Then I painted the cal.50 machine guns with black primer:
                    [ATTACH]322245[/ATTACH]
                    Then steel:
                    [ATTACH]322246[/ATTACH]
                    Black wash:
                    [ATTACH]322247[/ATTACH]
                    And graphite from a regular pencil:
                    [ATTACH]322248[/ATTACH]
                    Then, the loaders and ammo belts. As I heard in a documentary, ground crews used to fit some tracing ammo between regular rounds in order to allow the pilot to track their fire, so I painted red one of each five rounds:
                    [ATTACH]322249[/ATTACH]
                    Then I fit everything in place:
                    [ATTACH]322250[/ATTACH]
                    Now, lets put some wings into the main strut!
                    [ATTACH]322251[/ATTACH]
                    Well, this was mainly for the pictures, as the fuselage and wing panels must be cover the structure before joining them together.
                      Let's begin with that lovely silver skin of the mustang!
                      As you can see in this picture, I used three or four different tones of aluminium to have variety in the fuselage:
                      [ATTACH]322252[/ATTACH]
                      [ATTACH]322253[/ATTACH]
                      [ATTACH]322254[/ATTACH]
                      [ATTACH]322255[/ATTACH]
                      This wouldn't be a mustang if it doesn't have a colorful livery, so I masked part of the cowling:
                      [ATTACH]322256[/ATTACH]
                      [ATTACH]322257[/ATTACH]
                      And I painted it in brilliant red:
                      [ATTACH]322258[/ATTACH]
                      [ATTACH]322259[/ATTACH]
                      I made some scratches:
                      [ATTACH]322260[/ATTACH]
                      [ATTACH]322261[/ATTACH]
                      And then I placed everything over the fuselage strut:
                      [ATTACH]322262[/ATTACH]
                      On the left side I made the same, but using the parts of the models without the cowling:
                      [ATTACH]322263[/ATTACH]
                      And this is the big problem Barry warned me about...
                      The model allows you to build the nose with or without the engine cowling. But this "Frankestein" I decided to make, mixing both options... it just doesn't work because it leaves quite big gaps between the wing and the fuselage as you'll see.
                      But first, I had to place the windshield, so here you have the windshield process:
                      Masks:
                      [ATTACH]322264[/ATTACH]
                      Interior green:
                      [ATTACH]322265[/ATTACH]
                      And aluminium
                      [ATTACH]322266[/ATTACH]
                      I also painted the anti-glare band of olive green in the nose.
                      This olive green paint used to flake and change colour with the exposure to sunlight and rain, so I used the salt technique to imitate that.
                      First I paint a light tone of olive drab, then I shot some water and just add salt:
                      [ATTACH]322267[/ATTACH]
                      And then I painted the normal tone of olive drab. Once you remove the salt and paint some chipping, this is the result:
                      [ATTACH]322268[/ATTACH]
                      I had to replace the mask between colous and that left a small gap I tried to minimize with an oil wash (with poor results).
                      Well, that's all for today...
                      Regards!
                        Let's continue after a long Christmas break!
                        I made some chipping in the frontal coil:
                        [ATTACH]326147[/ATTACH]
                        Then I continued with the wings, starting with the main gear wells:
                        [ATTACH]326148[/ATTACH]
                        [ATTACH]326149[/ATTACH]
                        [ATTACH]326150[/ATTACH]
                        [ATTACH]326151[/ATTACH]
                        Then I painted some layers of aluminium lacqer from Alclad:
                        [ATTACH]326152[/ATTACH]
                        After that, I glued the outer pannels to the inner structure:
                        [ATTACH]326153[/ATTACH]
                        I used some masking to imitate the metal stress in the flaps (just as an experiment)
                        [ATTACH]326154[/ATTACH]
                        [ATTACH]326155[/ATTACH]
                        I also added the red wingtips:
                        [ATTACH]326156[/ATTACH]
                        I also worked on the main gears:
                        [ATTACH]326157[/ATTACH]
                        [ATTACH]326158[/ATTACH]
                        I used steel cable to imitate the hydraulic brake system:
                        [ATTACH]326159[/ATTACH]
                        And then... the marriage, joining the wings to the main fuselage:
                        [ATTACH]326160[/ATTACH]
                        The right side didn't look so bad, but the left side...
                        [ATTACH]326161[/ATTACH]
                        It certainly needed make up... this is what BarryW just said some weeks ago about misalignments.
                        This is what I did: First, masking:
                        [ATTACH]326162[/ATTACH]
                        After that, I worked with putty and green stuff:
                        [ATTACH]326163[/ATTACH]
                        Then, sanding and engraving:
                        [ATTACH]326164[/ATTACH]
                        And finally painting, and this is are the results after the make-up operation:
                        [ATTACH]326165[/ATTACH]
                        [ATTACH]326166[/ATTACH]
                        In addition, I will use some other tricks to mask this fitting misalignments, but I'll leave that for another day
                        Cheers!
                        • rtfoe
                          • 9100
                          You sure know how to get into the thick of things Judas. :smiling2: Good come back. :thumb2: With the price and detailing of a Zuokei kit I thought they would at least made the third option viable. I guess all the attention was on the engine.
                          I went thru all your steps...lovely and interesting using yellow and staining it rather than straight out of the bottle zinc chromate...saves on highlighting. It's looking real good so far. :thumb2:
                          • scottie3158
                            • 14221
                            • Holbeach
                            This is coming on nicely.
                              Thanks for your kind comments guys!
                              Let's keep going with this mustang.
                              I finished the main gear wells, with all the piping and lights:
                              [ATTACH=CONFIG]n[/ATTACH]
                              Then I started with the propeller:
                              Black Primer:
                              Marks and stencils:
                              Yellow tips, scratches and weathering:
                              Then a beautiful red spinner:
                              And finally the propeller in place:
                              I continued with the nice bubble canopy:
                              As the mustang was used mainly as an escort fighter, I decided to add two external fuel tanks.
                              Again, black primer:
                              A nice aluminium layer from ALCLAD:
                              Some decals:
                              And fuel stains:
                              Then I continued the dull work of placing the decals all over the model with Micro Set and Micro Sol:
                              And here is the result:
                              Just some minor details left and I'll post it into the finished models thread!
                              Regards!
