Revell 1\48 Eurofighter Typhoon twin seater
  • peterairfix
    • Jul 2012
    • 11083
    Not my usual type of kit but I thought I would give a go.
    First of all is to get rid of the horrible moulded seat belts and replace them with something better so I got myself some Eduard belt set.
    And here's the results with the finished along side the unfinished one[ATTACH]322940[/ATTACH][ATTACH]322941[/ATTACH]
  • peterairfix
    • Jul 2012
    • 11083
    Time to revive this build.
    When I retrieved this from the stash I have found out I did a bit more than I thought I did so I have two seats finished one IP done but with a dodgy decal two cockpit tubs started and I brought a front cockpit set for the forward tub as I have been unable to find a two seater setClick image for larger version
ID:	1102408Click image for larger version
ID:	1102409Click image for larger version
ID:	1102410Click image for larger version
      • 15810
      Hi Peter
      Amazing improvement with the aftermarket seat belts. Certainly worth continuing with.
      • peterairfix
        • Jul 2012
        • 11083
        All PE fitted in the front cockpit unfortunately I can't find any for the rear tub so its going to look rather bare.Click image for larger version
ID:	1102430Click image for larger version
ID:	1102431Click image for larger version
ID:	1102432Click image for larger version
ID:	1102433Click image for larger version
ID:	1102434Click image for larger version
        • peterairfix
          • Jul 2012
          • 11083
          Some more work done today some nice ejected pin marks to be sorted on the tail and the cockpit tubs fitted in nicely and the two fuselage sides fitted together nicely with no problems and lined up good with hardly any sanding needed.
          And using my usual type of weight for the noseClick image for larger version
ID:	1102483Click image for larger version
ID:	1102484Click image for larger version
ID:	1102485Click image for larger version
ID:	1102486Click image for larger version
            • 22788
            Nice work Peter
            • scottie3158
              • 14245
              • Holbeach
              Peter,
              Looking good.
              • peterairfix
                • Jul 2012
                • 11083
                Undercarriage bays started and installed in the lower wing also includes the air intake as well.Click image for larger version
ID:	1102568Click image for larger version
                • Si Benson
                  • 3572
                  That cockpit look brilliant Peter :thumb2:
