Dave Ward's Revell/ICM 1/48 Beech C-45F Expeditor
    Masking removed from the cowlings. Probably due to the number of coats of yellow, some bleeding has occurred.
    [ATTACH]325071[/ATTACH]
    Next, I'll have to mask off the cowls, and the de-icer boots on the wing, the I'll be able to get the wing sprayed aluminium.
    I've added the fuselage windows - there are 3 remaining cockpit glazing bits, that I'm painting the frames before adding to the model.[ATTACH]325070[/ATTACH]
    Not far off final assembly, it will all come together quickly
      That yellow has come out alright, and at least painting some green over it shouldn’t be any problem
      • Si Benson
        • 3572
        #33
        Yellow is a so and so, I remember from my Warhammer 40k days.
        The citadel paint had terrible coverage so I used to prime every thing in white!
          All yellow has terrible coverage, even worse than red. It doesn’t really depend on which paint you use (though some are better than others) because it’s inherent to the colour/pigments. Priming in white, or some better-covering colour close to what you actually want, like sand, is the best way to get it to cover OK, if you ask me.
            I masked the wings - using Tamiya masking film, and gave the wings a couple of misted coats of aluminium. Then, always a tense moment, the masks were removed....................[ATTACH]325305[/ATTACH][ATTACH]325304[/ATTACH]
            Not bad - no bleeding, I was very careful to press down the mask edges.
            The cockpit is glazed - these were a tight fit, and once they had eventually clicked into place, I decided to leave well alone - I'll have to deal with the gaps & retouch the paint, especially the glare panel shortfall, but generally OK[ATTACH]325303[/ATTACH]
            I don't know how I fouled that up - the other side is OK. I have the instrument panel to fit, and then I can think about uniting the 2 assemblies
              Parts finally united. Glue, of any sort removes the aluminium paint, so more touch up required. I should have given an overall gloss varnish before joining![ATTACH]325542[/ATTACH][ATTACH]325543[/ATTACH]
              After attending to the seams, I will have to gloss coat over all, before beginning the decal application. This is proving to be a challenging build, but I think will be worth it!
                I must say I like the looks of the plane in that metal finish.
                  Metal finishes look good, but they show up every flaw, and seem to mark very easily - I'll be glad when I can get a protective varnish coat over everything!
                    After a gloss varnish overspray, a light panel wash, and now ready for decals..............[ATTACH]326075[/ATTACH]
                    Taking much longer to make than I anticipated - but I'm still enjoying this build
                    • yak face
                      • Jun 2009
                      • 13840
                      • Tony
                      #40
                      Looking lovely now dave , its got very classic lines hasnt it? Cheers tony
                        Decals added, they're a bit thick, and don't seem to be reacting to the Decalfix, so I've given them another coat, and will leave overnight to really dry out[ATTACH]326215[/ATTACH][ATTACH]326216[/ATTACH]
                        not far to go now
                          Model Finished - pictures in the completed section
                          Thanks for looking in:thumb2:
