Hobbyboss 1/32 Spitfire Mk V - a collaboration
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4600
    • Bob
    • London
    #16
    Got the strips done, and the wing lights.
    Si vis pacem, para bellum.
    • scottie3158
      • 14201
      • Holbeach
      #17
      Bob,
      The paint work and leading edge strips look good.
      • Mr Bowcat
        SMF OG
        • Dec 2016
        • 4600
        • Bob
        • London
        #18
        Cheers Paul.
        • Mr Bowcat
          SMF OG
          • Dec 2016
          • 4600
          • Bob
          • London
          #19
          Hi guys,
          Small update, I made a start on the weathering with a clay wash. I'm just going for a grubby used look. I also tarnished the exhaust with some pigments.Click image for larger version
ID:	1088114Click image for larger version
ID:	1088115Click image for larger version
ID:	1088116Click image for larger version
ID:	1088117Click image for larger version
ID:	1088118Click image for larger version
            • 18266
            Very Nice restoration this.
            • Steven000
              • Aug 2018
              • 2827
              • Steven
              • Belgium
              #21
              Nice progress Bob :thumb2:
              Cheers Steven
              • JR
                • May 2015
                • 18273
                #22
                Bob.
                Just had a read through, what a battle royal to overcome that problem . Well done on the recovery, it's looking brilliant .
                John .
                • Mr Bowcat
                  SMF OG
                  • Dec 2016
                  • 4600
                  • Bob
                  • London
                  #23
                  Cheers guys.
                  • Mr Bowcat
                    SMF OG
                    • Dec 2016
                    • 4600
                    • Bob
                    • London
                    #24
                    Hi guys,
                    Small update. I got everything matt coated in preparation for the wheels and other last few bits to go on.
                    I decided to unmask the cockpit, at which point things went downhill. There was some sort of marking on the front screen and rear canopy. I tried cleaning it off but it appears that the actual plastic is hazed. Nothing I can do about it now so we will call it condensation.
ID:	1088563Click image for larger version
                    • Vaughan
                      • Apr 2011
                      • 3174
                      #25
                      Bob that's a real shame are you sure it's not masking tap resudue? I use Vallejo airbrush cleaner on a q-tip to remove it and it works for me.
                      • stillp
                        • 8093
                        • Pete
                        • Rugby
                        #26
                        That's a great shame after all that work.
                        • Mr Bowcat
                          SMF OG
                          • Dec 2016
                          • 4600
                          • Bob
                          • London
                          #27
                          Just found another problem. :sad:
                          The door was taped from the inside, I assume the original builder intended to have it open. Unfortunately it's not painted. :tired:
                          I have no idea what brand paint was used for the rest of the interior, I'm going to have to order some (probably Tamiya) to finish it off.
                            • 15687
                            Hi Bob
                            Just come across this. Sorry I didn't comment before. Well done to persevere after that green masking stuff. Paint job looks great and no doubt the painted roundels and numbers look better than decals. Shame about the canopy - very strange that frosting.
                            Not far to go now.
                            • Mr Bowcat
                              SMF OG
                              • Dec 2016
                              • 4600
                              • Bob
                              • London
                              #29
                              Cheers Jim.
                              Was hoping to get it finished today but will have to wait until I sort the door out.
                                Don’t you have a paint that comes close to what’s on the cockpit walls already? It’s a medium green, so you shouldn’t have too much trouble mixing something up, given the small amount you’re going to need.
