Dave Ward's 1/48 Revell Beaufighter TF.X 2018 Tooling.
    Whilst assembling the suspension on my Light Tank Mk VIB, my thought turned to something that promises to be a little simpler to build, new tooling 2018................Click image for larger version
    I have some rocket projectiles ( unused from a Mosquito ) that I will use ( the kit has the mounting plates, but no rockets or rails ), and I've got a decal sheet from ROPClick image for larger version
Name:	rop beaufighter.jpg
    The model will be big enough to spray the invasion stripes by masking - something I haven't attempted for many years ( miserable effort then! ).
    I'll be putting up some sprue & detail shots over the next few days, but I won't actually start butchering the bits until I finish the tank..............
    Whilst I am waiting for paint to dry on my VIB light tank, I've taken a few shots of parts on sprueClick image for larger version
ID:	1087385Click image for larger version
    The wing has the ports for the 6 machine guns, that I will have to fill for the TF.X with rocketsClick image for larger version
    The underwing panels to mount the rockets ( not to be used in the Revell assembly, and the radar thimble nose that I won't be using............Click image for larger version
    Alternative tailplanes.
    Multi - row Hercules engines
    Good clear transparencies
    A set of AP solid head rockets ( ex-Tamiya Mosquito ) for under the wingsClick image for larger version
    It all looks pretty good - although some of the sprue gates look a little bit heavy.
    I've done a bit of research on the TF.X, and it seems that it could have a large dorsal fin, and a thimble radar nose, and still have the same Mark name/number.
    There seems to be a bit of vagueness about the 6 wing guns, and when they were omitted. I've gone for no wing guns - extra fuel was carried in it's place & there was provision for carrying rockets or bombs under the outer wing. It's all a bit ambiguous!
    • BBdave
      • Aug 2014
      • 825
      Looks good do you get the torpedo?
        Dave,
        Yes, Torpedo, and aerotail ( wooden fins to stabilise it as it fell )
          Whilst waiting for the decals etc to dry on my VIB tank, I decided to finally do some work on this. Going totally out of sequence - I've made the engines - the sleeve-valved Hercules - the forerunner of the Centaurus - one of the most powerful piston engines ever producedClick image for larger version
          Don't think you will see much of the rear row of cylinders - but you can see the exhaust collector ring ( at the front ). I'm going to prime & paint these, then set them aside until needed.
          • BattleshipBob
            • 6792
            • Bob
            • Cardiff
            Hi Dave, looking good
            I have just got this, parts look good and crisp?
            Look forward to more progress
            Bob
              I made the Tamiya Night Fighter version of this many years ago - Typical Tamiya - superb fit - well engineered, but simplified, particularly around the undercarriage, and the engines. This model is much more modern, but like a lot of Revell models has good, and mediocre detail, and I suspect the fit will not be as good as the Tamiya. The 3 piece engine cowls look like they may be a but troublesome, but no doubt I will find out soon enough. There are some bits of flash & clean up is needed. Engines and undercarriage detail is good - the cockpit looks a bit spartan, but I'm sure careful painting will help.
              • JR
                • May 2015
                • 18273
                Dave will follow.
                  After an hour, or so, I've reached the stage of priming & basecoating the internals............Click image for larger version
                  The objects at bottom right are the ammunition boxes for the 20mm cannon - they have a decal to go on each - but at the moment, I am not sure if they can be seen when the fuselage is closed up...................
                  I'll prime black, then RAF interior green as basecoat.
                    This is what I love about acrylics - primed, basecoated & ready for detail painting in about 3
                    hours!
ID:	1088100Click image for larger version
                    And the engines - base aluminium, soon to be overpainted and washed..............
                    When the propeller & spinner and cowlings are added, only the front of the front row of cylinders will be seen.
                    • Mickc1440
                      • 4775
                      Following Dave, I've got a night fighter version in the cupboard.
                        Progress, the internals have been finished, painted, washed, decalledClick image for larger version
ID:	1088302Click image for larger version
ID:	1088303Click image for larger version
                        Fuselage closed up - not bad fit, masking tape used to hold it together - I'll let it dry overnight, then see how the seams look
                          One thing I have noticed is the instructions can be misleading. Before closing the fuselage, you are supposed to open two holes in the top......................Click image for larger version
                          The front hole, OK, but the rear one? you have to go forward to step 58. This is a hole to locate the extended tail fin - which I'm not going to use. Some of the choices are rather ambiguous. There are two types of stabilisers & elevators - I can't work out which to use, and photographs of Beaufighters aren't much help - I'm going to have to take a guess on that one. Added to the vague instructions is my main dislike of Revell kits - the paints callout. I can understand Revell specifying their own paints - but when it calls for 90-10% mixes, to make a colour widely available under it's proper name ( Dark Sea Grey ), then that's annoying!
                            It would help a lot if they mentioned the official name or (if there’s no such thing) a good, short descriptor followed by their own paint colour that works well for it. This goes for probably the majority of major manufacturers, whether they sell their own paints or not.
                            • yak face
                              • Jun 2009
                              • 13829
                              • Tony
                              Excellent progress dave , despite the trying instructions ! It looks a lovely kit , the full interior and properly detailed engines and no doubt accurately deep wheel wells are something thats usually missing or just plain made up on most beau kits , the old revell 1/32 being a perfect example. Shame because the 1/32 is a big impressive looking model , it just takes a hell of a lot of scratch building to get it looking right . Who knows maybe Revell will use these toolings and upscale them to 1/32 , that would be nice! Cheers tony
