Coming on great guns Dave...nice work.
Dave Ward's 1/48 Revell Beaufighter TF.X 2018 Tooling.
Decals sealed in with varnish - now onto some delicate painting - the canopies
Hand painted, then a cocktail stick used to scrape excess paint away. A little more scraping needed, I think.
The rockets make their first appearance.....................
These will be added, almost as the last operation.
DaveComment
Hi Dave
When I mask I use a thin cut strip of tape at the edges and work it into the detail. It's really important to stop that bleeding. I've heard of people sealing the edges with varnish, but I've never tried that. I then fill in the area to be masked, something like this 'Zebra' striped Dornier:
As far as possible I spray away from the edges of the mask, to avoid those annoying build ups along the mask. This horrible Revell kit (I must have made it for a bet or something!) came out like this:
I really had minimal touch up to do on the painting. I can see you've made a great job of sorting yours out, but it's bloody annoying having to do it!
SteveComment
Steve,
the larger the aircraft, the more tape you use, the greater the risk of bleed. The D-Day stripes, all being straight, makes it stand out more!
I have tried sealing the edges with varnish - however, the varnish proved to be pretty tough stuff, and when I peeled the mask off the whole varnish sealing peeled off - not to be tried again.
I did my1/48 ICM Hs126, using Tamiya Masking Sheet relatively easily (!?), at least the wing!.
Pretty flat wing, small(ish) segments...................
One of these things, you think you've got masking cracked, then a poor result dents your confidence
DaveComment
This almost counts as a stalled build, but with the TK tankette, and the Provost on the go, I didn't have enough room for this large beast.
Picked it up again, and added the undercarriage - I used CA to fix, as this is quite hefty.
I had almost forgotten that the outer flap sections had stripes- I'd better add them before rockets are installed.............................
DaveComment
