Barry, coming along, looking good.
Tamiya's Masterpiece - Their 1/32 scale Mosquito
I have applied oil stains and kerosene spills using AK washes
I also added the final fittings.
Removed the last of the masking.
There is a small blemish inside the canopy that really annoys me. I did not see it when I fitted the canopy. It is not too obvious thankfully
Here is the Tamiya Mossie alongside the HKM bomber version.
I will post a completed build ASAP. I did not have enough time left last night to take the photos.Comment
Before I start the next build I obtained two small cheap kits from John to be ‘mules’ to practise some weathering techniques I have not used yet. I will just be knocking them together very quickly.
I am not a fan of Revell and these were only £7 each but they are crisply moulded, though in a cheap brittle plastic. I cannot comment on fit and accuracy, they are very basic and the detail is not great, but I do believe they can be built up to make quite good models. I will not be doing so however and will get them both ready for my practise on less than an hour.
So if you want a cheap little fun kit, these do the jobComment
I just followed the instructions and only realised they are reversed when I put them side by side.Comment
[ATTACH]346537[/ATTACH]
… the Tamiya kit is correct, the HKM one has the colours the wrong way round.Comment
