Tamiya's Masterpiece - Their 1/32 scale Mosquito
    • 15817
    Hi Barry
    Impressive stuff. Is the detail on the fuselage walls from the kit or are there some scratched or aftermarket additions? Whatever it is very neatly painted.
    • BarryW
      • Jul 2011
      • 6032
      #62
      It is all kit detail Jim. I will bring out the detail further when I do washes and dry brushing.
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #63
        Barry ive been tryin to make out what the white sign says on the door but no joy could you tell me ?
        chris
        • Gary MacKenzie
          SMF Supporter
          • 1059
          • Gary
          • Forres , Moray , Scotland
          #64
          Its a beware of the props sign i think , but cant work out exact wording
          • colin m
            • 8806
            • Colin
            • Stafford, UK
            #65
            All looking great Barry. I've only built two of these amazing Tamiya things. Watching your build has got me 'browsing' the web again !
            • BarryW
              • Jul 2011
              • 6032
              #66
              That is correct and it can clearly be read on the model.
              I have done some washes and dry brushing and the detail really pops. The wash I used was a brown one and that along with brown pigment helps give the impression of the wooden structure.
              I use Uschi met powder, carefully and sparingly, on the metal areas to depict painted metal and chipping. The pigment and wash also helped create a feel of dust and dirt. Had to be careful not to overdo it.
              • BarryW
                • Jul 2011
                • 6032
                #67
                I am pleased to report that despaired all that complexity the fuselage halves fit perfectly.
                I have held the parts together with tape while placing drops of Mr S Cement between the masking tape to tack the sides together, in half an hour I will remove the tape and run more cement along the seam and then tomorrow I will treat the seams. You can see how few places I have had to use tape in so naturally do the parts fit.
                Below I have prepped some more parts for painting.
                  It says “Beware of airscrews”. I first thought it might say something like, “Do not open in flight”
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #69
                    Originally posted by Jakko
                    It says “Beware of airscrews”. I first thought it might say something like, “Do not open in flight” :smiling3:
                    To me it looks like BEWARE OF PROPELLER'S
                      I cropped, straightened (more or less), enlarged and sharpened up Barry’s photo, and it definitely says “BEWARE OF AIRSCREWS”:
                      [ATTACH]336344[/ATTACH]
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #71
                        [ATTACH=CONFIG]n[/ATTACH]
                        OK Jakko you are right :astonished:
                        • Peter Gillson
                          • 2594
                          #72
                          very impressive so far
                          • scottie3158
                            • 14253
                            • Holbeach
                            #73
                            Barry,
                            This is a cracking build.
                            • BarryW
                              • Jul 2011
                              • 6032
                              #74
                              Getting along well with the main fuselage construction. The model will be ‘closed up’ except for the bomb bay. So I have fixed some panels in place. I have also treated the seams by running a bead of Mr Dissolved Putty along them and sanding. In some places I ‘wet sanded’ to preserve detail.
                              Bottom up!!!
                              And top down!
                              The tail components fit like a dream. No filler
                              anywhere needed.
                              I will start on the two beautiful Merlins next.
                              I should try to get a better shot of the internal detail now it is closed up.
                              • Vaughan
                                • Apr 2011
                                • 3175
                                #75
                                Very nice Barry it's really coming along.
