Tamiya's Masterpiece - Their 1/32 scale Mosquito
  • colin m
    • 8770
    • Colin
    • Stafford, UK
    #121
    Just having a catch up Barry. All looking great. My only worry is, whatever you build next, you might just be a little - let down by the kit ?
      • 15746
      Not if it's the new 1/24 Airfix Hellcat!
      • Peter Gillson
        • 2594
        #123
        Excellent craftmanship. Great model
        • BarryW
          • Jul 2011
          • 6029
          #124
          That Hellcat looks a nice kit and I may well be tempted but my concern is that like the Typhoon in that scale while the engineering will be superb the manufacturing will let it down. That awful soft poor quality plastic Airfix uses is a real problem. With the Tiffy you spend as much time cleaning the mould lines, sink holes and filling gaps where the plastic clearly shrunk, as you do assembling the parts.
          • BarryW
            • Jul 2011
            • 6029
            #125
            Well I have joined the fuselage to the wing. Once again while a complex mix of shapes to bring together the fit can only be described as perfect.
            A screw gives a really good strong join, supplemented by liquid cement brushed along the seams.
            [ATTACH]340225[/ATTACH]
            Take a look at that cockpit, not to mention those joins....
            [ATTACH]340224[/ATTACH]
            The underside fit
            [ATTACH]340226[/ATTACH]
            An overview.
            [ATTACH]340227[/ATTACH]
            • scottie3158
              • 14221
              • Holbeach
              #126
              Barry,
              Great work as always. You are not wrong for your praise for this kit the fit looks superb.
                • 15746
                Hi Barry
                That last set of photos show what a great kit this is and what a superb job you are doing with it. The detail is stunning.
                • stillp
                  • 8097
                  • Pete
                  • Rugby
                  #128
                  Looks very good from here!
                    An amazing level of detail in the kit, brought together and finished superbly.
                    • BarryW
                      • Jul 2011
                      • 6029
                      #130
                      I have started to pull together the front cannon assembly
                      Note the p.e. jigs to ensure that the barrels have the right spacing. These will be removed before the next stage of the assembly, more thoughtful Tamiya engineering.
                      I will not be leaving this area open to view but I will have the bomb bay open.
                      • BarryW
                        • Jul 2011
                        • 6029
                        #131
                        I am having the bomb bay section open and gun bay closed or on other words ‘half open’ as per the Tamiya description.
                        The bomb bay doors come as a single piece so some cutting is required.
                        I used tape to provide a guide to the cross cut.
                        [ATTACH]340640[/ATTACH]
                        I then used my finest razor saw to cut, working slowly and letting the saw do the work.
                        Here it is after cutting needing only a swipe of a sanding sponge
                        [ATTACH]340641[/ATTACH]
                        I then did the same to separate the two bomb bay doors.
                        [ATTACH]340642[/ATTACH]
                        Her is a view of the next lot of sub assemblies ready to paint except for the two bombs as I have some sanding to do having treated the seams with Mr DIssolved Putty
                        [ATTACH]340643[/ATTACH]
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #132
                          Fantastic build Barry whats happenin on her now ?
                          chris
                          • BarryW
                            • Jul 2011
                            • 6029
                            #133
                            Progress seems rather slow this week
                            Here are some bomb bay parts painted, weathered and ready to install
                            [ATTACH]341537[/ATTACH]
                            Between waiting for parts to dry I have been pulling together various sub assemblies.
                            [ATTACH]341536[/ATTACH]
                            • Steven000
                              • Aug 2018
                              • 2830
                              • Steven
                              • Belgium
                              #134
                              Looking good Barry :thumb2:
                              Cheers, Steven
                              • AlanG
                                • 6296
                                #135
                                Seriously excellent build Barry. Wish i could afford one of these beauties
