Post War 1/72 FAA - Part 1 - Sword Fairey Gannet AEW.3
Name:	sword gannet.jpg
ID:	1091938Click image for larger version
    This will be first of 5 FAA aircraft I intend to build - the others, in no particular order, are, Sea Venom, Sea Vixen, Sea Hawk. and Gannet AS.
    The Sword model is a limited run kit, with a tiny PE fret, and resin parts ( more on this later )
    Sprue & other parts
ID:	1091926Click image for larger version
ID:	1091927Click image for larger version
ID:	1091935Click image for larger version
ID:	1091937Click image for larger version
    There are resin parts for the radar operators cab, but I'm not going to use themClick image for larger version
    You have to cut the hatches out from the fuselage & replace them with resin parts - even then the view will be limited, so no thank you.
    The Gannet is a limited run kit, which means clean up & dry fitting will be very important.
    A few detail shots
ID:	1091929Click image for larger version
ID:	1091930Click image for larger version
ID:	1091931Click image for larger version
    Some of the detail is a bit heavy, for 1/72, but may look OK under paint.
    This is the sort of thing you have to be aware of:Click image for larger version
ID:	1091933Click image for larger version
    Upper & lower tailplane - no locating pins, and ejector pin towers on the mating faces.
    Of the two versions, I think I'll go for the 1968 HMS Hermes - with full red/white/blue roundels.
    I'll be finishing my Saurer, but will start on the construction of this when paint/varnish/washes are drying.
    • 18955
    Interesting subject, be interesting to see how it works out....itโ€™s an ugly looking beast though....
    • yak face
      • Jun 2009
      • 13871
      • Tony
      Brilliant , i love a series build , really looking forward to the progress. Great choice of subjects too , this one looks a typical limited run , but nothing a bit of good old school modelling wont sort out. BTW if you think this is a bit rough you want to have a go at an Amodel kit!!, cheers tony
        • 22788
        Think Iโ€™ll pull up a chair for this Dave.
        • Neil Merryweather
          • Dec 2018
          • 5207
          • London
          I'm watching this one ,Dave
          I've got a soft spot for the FAA myself
            Iโ€™ll be watching with interest!
            • Lee Drennen
              • 7711
              Very nice Dave
              • dave
                • Nov 2012
                • 1829
                • Brussels
                Interesting to watch this one, always had a soft spot forth Gannet, even if it is a bit of an ugly duckling.
                  Watching this.
                    Construction finally starting.............
                    The instrument panel PE & film added together Click image for larger version
                    The cockpit assembly, ready for primingClick image for larger version
                    I'm going to add a pilot - don't think a lot will be visible, at the finish.......Click image for larger version
                    The wings: the undercarriage wells are built up from flat parts - note that there are no locating pins, and all mating faces have to checked and preparedClick image for larger version
                    Due to the short run nature, you have to be aware of problems.......................Click image for larger version
                    On this half of the fuselage, you can see a 'lip' along the edge - the other half doesn't have one! You can either remove it before, or after assembly. I'll do it after joining the halves, just personal choice.
                    • Mickc1440
                      • 4786
                      Ugly duckling it may be but looking forward to seeing what you do with this one Dave
                      • Fernando N
                        • 2448
                        Nice start Dave and good luck with this short run one.
                        Neat chosen scheme too, simple and functional just like the plane :thumb2:.
                          In my exploration of the darker part of my stash - I found an Aeroclub vac-form conversion for the Frog Gannet and half the fuselage of the donor model - top to bottom - Sword Gannet AEW, Aeroclub Gannet AEW, and Frog/Novo Gannet ASClick image for larger version
                          The brown plastic Gannet, with crew heads moulded in situ Click image for larger version
                          The pilot, and cockpit for my Gannet - a dry fit reveals ( or actually doesn't ) that the instrument panel will be hidden..............Click image for larger version
                          There is no mention of nose weights in the instructions - but I think I will have to make provision for some between the cockpit floor, and the nosewheel bay
                            • 15816
                            Hi Dave
                            I like the FAA project. This is a very iconic aircraft - served its purpose well. You seem to have everything in hand, recognise the problems of a short run models.
                              Jim,
                              many years ago, I used to make vacforms of the more obscure aircraft - short runs kits are much easier!
