Academy P38 lightning
    • 22770
    #16
    Looking good so far Tony ive got one in the stash but saving it just incase the twinboom makes it as a gb or sig
    • mossiepilot
      • Jul 2011
      • 2272
      #17
      Here are some more pictures, the base coat is on, brush painted with Tamiya acrylics, so the finish is not so good.
      But learning all the time.
      The cockpit conopy is about to be masked for painting
      Any comments and advice gladly received.
      Tony.
      ps Sorry the pictures are a bit fuzzy, still learning to do that too - lol
      [ATTACH]40781.IPB[/ATTACH]
      [ATTACH]40782.IPB[/ATTACH]
      [ATTACH]40783.IPB[/ATTACH]
      [ATTACH]40784.IPB[/ATTACH]
      [ATTACH]40785.IPB[/ATTACH]
      [ATTACH]40786.IPB[/ATTACH]
        Good work so far...
        Watching progress...
        • yak face
          • Jun 2009
          • 13840
          • Tony
          #19
          Looking good tony, nice to see another lightning , looking forward to seeing the end result , cheers tony
            Hi Tony, looking good, cracking work so far mate!
            Cheers, Andrew
            • mossiepilot
              • Jul 2011
              • 2272
              #21
              Thanks for the encouragement Andy.
              Tony.
              • mossiepilot
                • Jul 2011
                • 2272
                #22
                Oooo Bugger, I think I've just ruined the canopy.
                I masked the canopy and used the Wilkinson primer and then painted over that with my Tamiya acrylic, looked nice, but when I took the masking off, I found that the primer had blown under the canopy edge and got onto the inside surface, I had put some masking tape on the inside and stuck it down to a piece of newspaper with some blutack. oster_oops:
                I tried to scrape it off with a toothpick but it's stuck fast. the more I tried the worse the clear parts looked. Also the Tamiya topcoat started to come off, even though I had let it dry for 24 hours.
                OK, Tamiya acrylic paint is rubbish for brush painting, learn't that lesson now.
                Live and learn. I'll complete this as best I can, but I've lost all enthusiasm for it.
                Tony.
                ps sorry about rubbish photos too:whatever:
                [ATTACH]40845.IPB[/ATTACH]
                [ATTACH]40846.IPB[/ATTACH]
                [ATTACH]40847.IPB[/ATTACH]
                • colin m
                  • 8750
                  • Colin
                  • Stafford, UK
                  #23
                  And it was going so well. All is not lost. Now I can't help you personally (I've not been in this situation yet) but I remember someone on this forum using either (or maybe both) brasso / toothpaste to polish a canopy. So if this is correct, you could use some pretty tough paint remover, just white spirit etc - what ever you need to remove the paint you used, and then restore the canopy by polishing. This sounds like a job for google ! Good luck. oh yes, what about a vacform replacement canopy ?
                  Colin M........
                  • mossiepilot
                    • Jul 2011
                    • 2272
                    #24
                    Thanks Colin.
                    Was really p****d off when I found out what I had done.
                    Lots of gnashing of teeth and hair pulling :fool:.
                    But gonna use this as a learning.
                    Move on and do better next time.
                    Tony.
                      Tony that really bites the big one,maybe a clear alternatives a/m replacement is in order they are easy to find on evil bay. I too have heard that you can polish them back out with brasso but have'nt tried it.
                        You could try a drop of isopropyl alcohol, that might shift it
                          or try sanding with sandpaper 2000 minimum, and after that... tuth paste and brush with some good quality cotton
