Another small update I have all the tail wheel parts painted and ready to put together and I have got the cockpit\engine assembly fitted in one side of the fuselage.
More work done this time I have it buttoned up it needed a little bit of filler
And I have started on the wings and main landing gear and a few machine guns painted
By the end of the day it now looks like this and I will be leaving it for a couple of days to set properly and as you can see it's needed a lot of tape to put in the right place.
After an overnight dry the wings have settled nicely but I was warned about the terrible fit around the nose section and it seems to ring true as it's out with my old friend the filler.
And here's the state.
