True
But it was about the only information I could find on a quick search.
Micro Sol does evaporate — I had bottles of Set and Sol of which the caps cracked after a couple of years, and the contents did too, eventually.
That’s easy enough to try to see if it works. Not that this would be much cheaper than using Micro Sol, though, so it’d only be useful if you happen to have run out of actual decal softener.
