Richards Kinetic 1/48 F-18D
  • rtfoe
    • 9114
    #61
    Thanks Tony, the basic kit is not too bad if you're not expecting a super flawless mold. I just had a fight to install small etch frets to hold the intake shields. The instructions obviously showed it at the wrong position which I thought not logic. Luckily a quick look at references showed it installed further down at the corner. Still it took me a while to get both aligned...
    The F-18 has a rugged look to it which fits the Marines tough persona. Getting it to this stage is a relief. I have decided the only putty to fill intakes is Magicsculp. Easy to apply and smoothen with a damp brush or cutip.
    Go for it Tony and make sure to post it here.
    • flyjoe180
      • Jan 2012
      • 12463
      • Joe
      • Earth
      #62
      Looking good Richard, very nicely done so far
      • rtfoe
        • 9114
        #63
        Thank you Joe, so here's the pre-shading in progress...
ID:	1107745Click image for larger version
        It's the first pass and halfway through. The next pass will determine the darker areas, paneling and the streaking.
        • Steven000
          • Aug 2018
          • 2830
          • Steven
          • Belgium
          #64
          Looks very nice Richard :thumb2:
            • 15799
            Hi Richard
            Watching your preshade very carefully. I will get that technique right if it kills me :angry: You always get a very nice result.
            • rtfoe
              • 9114
              #66
              Thanks for looking in Steven and Jim.
              Jim, basically its creating the look on the canvas before applying a tint of the top coat. So with the use of heavy tones of black and whites I basically weather the surface without the worry of overdoing it because varying the final top coat of tinting layers can reduce or keep the shading heavy. The good thing is the top coat shades will appear as a darker or lighter version of its hue. I have seen many make the mistake of using black as post shading when it should be the mix of the top coat and a darker shade to get the same result as pre shading. I hope I'm making sense. :smiling3:
              Anyway I hope my process shows the method.
              • rtfoe
                • 9114
                #67
                Hi just another shot with the other wing pre-shaded and a second pass to darken certain panels...
                Coming up next will be white and grime.
                • rtfoe
                  • 9114
                  #68
                  Here's the white applied to the pre-shade. Doesn't look much but it is there. The F-18s weren't as splochy as the F-14s as they were newer I guess.
                  This was done over at the night build in our LHS. I used their airbrush and was getting to grips with it.
                    • 15799
                    Hi Richard
                    The secret, which you have mastered, is to build up with very misty coats. It is the skill of using the airbrush both to get the preshade correct and the misted on top coats. I will conquer the technique :smiling:
                    • rtfoe
                      • 9114
                      #70
                      Originally posted by Jim R
                      Hi Richard
                      Hi Jim, yes that's the method. It's also the kind of paint you use and how translucent it is to manipilate the degree of the shade showing through. I think you've nearly got the hang of it with your heli.
                      • rtfoe
                        • 9114
                        #71
                        Hi Jim, back home again and have taken shots of what was finished at the LHS last night...
                        The results of the layers that covered the pre-shading. I got the subtle look that I wanted but not for the grey tone for the underside as the variation of the grey is so close. I found out that I hadn't added the white pre-shade to the bottom so the black overpowered the light grey.
                        But I'm happy with the top and just need to re-work on the fins as they should have the lighter underside grey.
                        There is a distinction or hint of the different greys near the back formation lights but not the fin...
                        There is prominence on the nose and thats where I realised the white base will solve it.
                        • Wouter
                          • 742
                          #72
                          That's some very tasty paintwork going on here mate.
                          • Steven000
                            • Aug 2018
                            • 2830
                            • Steven
                            • Belgium
                            #73
                            Yes, that looks very nice Richard, subtle and refined work :thumb2:
                            • scottie3158
                              • 14243
                              • Holbeach
                              #74
                              Richard,
                              I'm always jealous of your skills with an airbrush very nicely done.
                              • Si Benson
                                • 3572
                                #75
                                Now that looks daโ€™ business Richard
