Morning all as it's another fine summers day I've decided to start another Tamiya kit and here she is.[ATTACH]345189[/ATTACH][ATTACH]345190[/ATTACH][ATTACH]345191[/ATTACH][ATTACH]345192[/ATTACH]
Tamiya Spitfire 1/48
Cockpit assembled ready for painting. Those spitfire pilots didn't have a lot of room did they![ATTACH]345222[/ATTACH][ATTACH]345223[/ATTACH][ATTACH]345224[/ATTACH]Comment
I've decided to open the door up.
[ATTACH]345233[/ATTACH]Attached FilesComment
Nice start John:thumb2:, I’ll follow along if you don’t mind.
Have the same kit and interested to see how yours ends up. :smiling:Comment
I once read somewhere that for an American fighter jet (don’t recall which one, but probably one of the 1970s–80s ones), there is a special and very expensive tool that's used only to remove and install a couple of bolts in the cockpit — bolts which a normal spanner also fits onto just fine. The reason for the tool is because it will prevent the bolts being accidentally dropped. That in itself wouldn’t be too bad, except if dropped they apparently have a tendency to get in such a position, that when someone gets into the pilot’s seat and drops it to its lowest position, the seat’s rocket will fire …Comment
When they first started letting people sit in the Spit at Hendon, one of the staff dropped his security pass as he was getting in. It took 3 days to recover it...
I heard a story from a trustworthy source, that a Harrier was lost following the replacement of something in the instrument panel. A screw was dropped, and during flight worked itself into a position that prevented one of the controls from reaching the position necessary for landing, so the pilot had no choice but to eject.
PeteComment
