Eduard\Revell British S.E.5a
  • peterairfix
    • Jul 2012
    • 11075
    Not done a biplane in a while so I have this one in my stash to butcher while I wait for so stuff through the post for my nex main project.
    This kit is a direct reboxing of the Eduard kit and as ever it's a quality kit with lots of nice tiny pieces to lose there won't be much airbrushing as the part's are so small I will brushing most of the kit
    Here's some of what I have done it's mostly paintwork.
    And for size indication all those squares are one centimetre.Click image for larger version
ID:	1097557Click image for larger version
ID:	1097558Click image for larger version
ID:	1097559Click image for larger version
ID:	1097560Click image for larger version
ID:	1097561Click image for larger version
ID:	1097562Click image for larger version
    • 22770
    Nice start Peter.
    • flyjoe180
      • Jan 2012
      • 12407
      • Joe
      • Earth
      Nice work Peter, prop looks good.
        Very impressed with the effect on the propeller blades.
        How did you do it?
        • JR
          • May 2015
          • 18273
          Peter.
          I'm in, oap seating with nurse please.
          If the prop is a taste of what's going to follow it should be good .:thumb2:
          • peterairfix
            • Jul 2012
            • 11075
            How did you do it?
            I first did a coat of tamiya wooden deck tan.
            And then I used thisClick image for larger version
ID:	1097771follwed from the set above I first dry coated in the first shadeClick image for larger version
ID:	1097772And then a light coat of this to get the grain effect and topped off with a coat of mig gloss varnish.Click image for larger version
              • 15703
              Hi Peter
              The number of kits which get reboxed, updated, new decals etc can be very confusing. Eduard are usually nice kits. Some of those parts are indeed tiny. As others have said the wooden prop is very realistic.
              • peterairfix
                • Jul 2012
                • 11075
                Started on the the cockpit and as ever it's a bit fiddly but I did get together and a bit more wood staining still needs some work.Click image for larger version
ID:	1097819Click image for larger version
ID:	1097820Click image for larger version
                • peterairfix
                  • Jul 2012
                  • 11075
                  Cockpit finished and bracing wires added and now sat in the bottom wing.Click image for larger version
ID:	1097913Click image for larger version
                  • scottie3158
                    • 14201
                    • Holbeach
                    Peter,
                    Nice work so far the cockpit stringing looks good.
                      • 22770
                      Looking good Peter, very nice work on the cockpit.
                        Very nice. Love the woodwork.
                        • peterairfix
                          • Jul 2012
                          • 11075
                          Here's today's work started on the two fuselage sides made up the engine and have it seem up and engine installed.Click image for larger version
ID:	1098016Click image for larger version
ID:	1098017Click image for larger version
ID:	1098018Click image for larger version
ID:	1098019Click image for larger version
                          • peterairfix
                            • Jul 2012
                            • 11075
                            Almost finished just rigging and decals to go but with the thickness of the rigging it might be another few weeks before it's done.Click image for larger version
ID:	1098151Click image for larger version
ID:	1098152Click image for larger version
ID:	1098153Click image for larger version
ID:	1098154Click image for larger version
                            • flyjoe180
                              • Jan 2012
                              • 12407
                              • Joe
                              • Earth
                              Looking good Peter, good luck with the rigging
