Interesting Roman what do you use to thin the Revell paint as it is too thick to spray directly from the pot?Vaughan
Hey Vaughan,
I always mix acrilic paint with destil water... nothing else, and ratio is about 50-50%.
For my oppinion, primer is used for seeing errors on model, and many times when plastic is no cover with paint you cannot see errors (i mean gaps, panel lines, etc.)
And when I "inspect" model and I'm sadisfied with look, put color on it, but if I see some error I can easily put more putty, sand or do something on that acrilic paint.
This is my way
here you can see primer and preshade
also must say that this color STONE GRAY is really good color, because is always different from plastic color... and you can see everything when you spray it on model
Now I have doubt... searching for that plane reference on the net, cannot found anything. Just 1 picture of Alfred Grislawski when he sitting near the rudder of this Bf-109.
I see on some art underside capotage is paited in yellow, on other art no yellow color?
